Question about Kenmore HE2 Plus Front Load Washer
Washer stopped and (Sud) shows in time area - Kenmore HE2 Plus Front Load Washer
  • 10,319 Answers
SUD stands for too much detergent. If you add the proper amount the sensor is at fault for the measuring of this
Posted on May 29, 2010
Washer stops running and displays code SUD. The water doesn't drain until It's put on the rinse/spin cycle.
Make sure you are using HE (High Efficiency)detergent. The codes could mean your washer is telling you it has used a built in "SUD" routine during final rinse
Jul 18, 2015 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
The washer beeps and gives the letter f and sud
Time to clean up the pump area and stop using too much soap. Remove the base panel8806409.jpg2e21b5a.jpg2eb5cf5.jpgb81be45.jpg More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does SUD mean?
SUD means a detection of suds in the machine. These machines are very sensitive to over sudsing. Try adding just plain water or bleach to break down the suds level. They say to use 1/4 of the detergent you would use in an older machine.
If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle finish
If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Jul 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Error code F 35 and SUD code
Save yourself a lot of time and money and replace the analog pressure switch. This will solve your issues by taking care of both error codes at the same time.
The Appliance Pro
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
Jan 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
HE5t Steam shows SUD then f35. I have unplugged it. Plugged it back in; started a rinse only cycle and still it show this error. The washer is empty. I check the sensor on the back right hand area that I...
SUD means there are too many soap suds in the washer. Are you using a front load approved detergent? Are you using the correct amount? or slightly less is better.
May 12, 2017 | Kenmore Elite HE5t Washer
He3t
Check out your outlet filter, access from the front bottom right. Next open up behind to check the pump area, also the tube which comes down from the tub. There should be some blockage somewhere. Plug off the wall first. Your need a good grip plier to release the grip clamps. Perhaps you could change to front loading powders?
Nov 27, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
