Question about Saeco Primea Cappuccino Touch Plus Coffee Maker
Anyone have repair manual/service manual for the Saeco Primea Touch Plus? I have the user manual, but that is not helpful to my problem. I have got the "error code 1" on the display, anyone who have solved this by them self? I asked the service center, they say it can be the grinder, motor or sensor. Thanks in advance..
  • 74 Answers
SOURCE: Saeco Primea Touch
No it is not. :)
Posted on Jul 11, 2008
JohnnyBeans
  • 223 Answers
SOURCE: Saeco Primea Touch Plus flow problem
In the bean hopoer there is a little screw. Remove this screw and the cover and you will see an adjustment alan key. You need to push down and rotate the adjuster counter clockwise to make it finer and clockwise to make it bigger. Make sure you only rotate the grinder a little at a time, 1/4 turns at a time recommended. Make 2 cups then readjust if necessary.
Saeco Authorized Sales & Service of Espresso Machines
www.CeriniCoffee.com
Posted on Nov 30, 2008
SOURCE: My saeco primea touch plus cappucino grinds coffebeans, but no co
At the extreme top left of the brew group, above the last filter (mentioned in another response), there is a spring loaded tip that I assume is pushed open by the pressure of the brewed coffee, before the coffee streams to the dispenser nozzles. When I dis-assembled this (2 philips screws) the tip seemed very sticky (slightly jammed?). I pushed the ip several times against a hard surface and freed it up. Re-assembled everything (plus cleaned the last fliter). Works fine again.
Posted on Jul 25, 2009
  • 20 Answers
SOURCE: error 1 on saeco primea touch plus
The grinder motor is not working,,better to take it to the service center to replace a new one under warranty if the machine is new.
Posted on Dec 16, 2009
  • 20 Answers
SOURCE: Hi, I have the Saeco Primea
Need to prime the machine. The new water filter is causing the air lock in the system.Remove the filter and startup the machine it should prime by itself, when it's ready,fit the filter back and press hot water until the water flows steady. Hope it helps.
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
My Saeco Primea Touch Plus every time I turn it on says to add detergent at the milk conteiner. After I give the comand it tryes to wash the milk conteiner and when this is finished says to turn of the...
From what the User Manual indicates, the prompt to clean the milk circuit is based on the number of days since the last time this was done. The counter which keeps track of this is probably only reset at the completion of the wash cycle. You might be missing a step.
The User Manual is available here, see page 28. There are 16 steps plus the "perform another rinse cycle" (page 27):
https://www.seattlecoffeegear.com/assets/user-manuals/saeco/saeco-primea-touch-plus-user-manual.pdf
Jan 14, 2018 | Saeco Primea Cappuccino Touch Plus Coffee...
Error 1 on saeco primea touch plus
Oct 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Hi, I have the Saeco Primea Cappucino Touch Plus , and it syddenly gives the error code 5 - Call assistance. I have just changed the primea Water Filter - same way as always ! What can I do ?
Sep 05, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Flow
Check your grinder to see if the grinds may be too fine. Increase the grinder size and see if the coffee speed is increased.
If not, Contact saeco usa for support at 800-933-7876.
Out of warranty repairs can be completed by Cerini Coffee located in New York.
Replacement parts for your saeco espresso machine located at http://cerinicoffee.com/Saeco_replacement_parts.asp.
Nov 23, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
195 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
