Question about Coby TF-TV3217 32 in. LCD TV
My 32 inch Coby HDTV is stuck in the mute mode. The remote still works with the volume and on and off mode but will not work to turn off the mute mode.
  • 8 Answers
SOURCE: hook up speakers to 32 inch lcd hdtv
"Line" level audio output is available at the audio output phono jacks at the top of the rear panel, but not speaker-level output. So, you'll need an amplifier to use in conjunction with your external speakers. (An alternative would be "powered" or "amplified" speakers that have their own amplifier, but often are less satisfactory acoustically). You don't necessarily need to get a full-fledged "receiver" with multiple in's & out's... I simply used an inexpensive stereo amplifier.
Connect the "Audio L - R" jacks on the rear of the set to the "line" or "aux" inputs on your chosen amplifier and speakers. If you go into the set's Menu - Option - Output Select and set it to "Variable", the internal speakers will be disabled, and you can control the volume (and muting) of the audio sent to the amplifier, and still have "armchair" control of the volume as before... but now with better stereo!
Posted on May 22, 2009
  • 814 Answers
SOURCE: My element 32 hdtv does not want to stay on
These units are having a problem with component failure. This has caused the television to got into the protection mode.This protects the unit from more damage. The units need to be taken to a service center for complete testing and service.The service center will have all the service information to evaluate the problem and repair the unit. The Element customer support telephone number is 1-888-935-8880. The Element customer support website is: http://www.elementelectronics.com/support.html Give them the model number of your television and the problem you are having with the unit failing to turn on.They will be able to tell you how to get you television serviced. I hope this information helps you with your problem.
Posted on May 29, 2009
  • 12 Answers
SOURCE: No Sound on Samsung HDTV? But there is a picture...?
have you tried to umplugging the tv and let it sit for a little while. I would unplug the tv like before you go to bed and plug it back in in the morning and try it
Posted on Nov 18, 2009
Testimonial: "Well, I unplugged it for several minutes, and that was enough... thank you very much!"
SOURCE: cant use fios remote to power/volume
THANKS 0490 WORKED ON MY DYNEX 32" LCD FOR MY VERIZON REMOTE.
Posted on Dec 08, 2009
UpGrade
  • 113 Answers
SOURCE: How do you replace a remote sensor in Vizio 32
Pull the back off of the screen and look at the bottom between the two speakers you will see a little box with a few wires going off to one of the printed circut boards. I have never seen one fail before, most of the time its the remote/dead batteries etc.
Posted on May 22, 2010
Sony KDL-32S3000 BLINKS 5 TIMES STUCK STANDBY MODE
Remove all speaker wires and try again. If it unlocks one or more speakers are bad. If not service required for amp. Good luck.
Apr 16, 2014 | Sony Bravia S-series Kdl-32s3000 32-inch...
Remote control from Dish tv will not work volume on Coby 32" flat screen
This is not unusual--Dish and other remotes even if program will not have all the functions that may be needed---
Dec 03, 2012 | Sharp LC-32SB24U 32 in. LCD TV
I can't program my direct tv remote to my coby TFTV3225 TV. Don't have the right codes. Does anyone know the codes?
11531 is the code given by DirecTV for this model. To enter this code . . .
1. Slide the mode switch at the top of the remote to the TV position
2. Hold both the MUTE and SELECT buttons until the LED blinks twice
3. Enter the 5-digit code 11531
4. Test the volume and power buttons for correct operation with the TV
If the code does not work first time, try entering the code a couple more times. If it still doesn't work, also try code 11436. DirecTV do not list any other codes for your TV, so if they don't work, it's possible that the remote will not work with your TV. There is also a code search option which tries every code in the remote. If this doesn't work, the remote definitely will not work with your TV.
Please try the codes above and let me know if you need further assistance or the code search instructions. Also, remember to slide the mode switch back to the DirecTV position after you have finished entering the codes.
Regards,
BElectric
Apr 24, 2011 | Coby TFTV3225 32 in. LCD TV
My samsung 32 inch turns on goes to white snow screen but I get no volume the buttons don't work and I tried a universal remote and yet nothing seems too work. Help me please.
moa
replace caps in psu panel and eprom or try factory reset switch tv to standby then mune mute info stanby buttin on remote if you get service mune try reset.
Aug 17, 2010 | Televison & Video
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Headphones on my dynex 42-inch tv the speakers are still on
Use the MUTE button on the remote to mute your TV speakers and then you can still use our headphones. You can continue to adjust volume with the remote and it will only affect your headphones. You may need to do this each time you turn on the TV and use headphones, but that is a small annoyance.
Dec 26, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Push the MUTE button on the TV remote to restore audio.
Nov 18, 2009 | Samsung LN-T3253H 32 in. LCD Television
Volume not working on TV
TRY CHANGEING THE MONO STERO MODE IN THE AUDIO MENU. ALSO CHECK TO SEE IF YOU ARE IN MUTE MODE AND INTERNAL SPEAKERS ARE TURNED ON.
Dec 25, 2008 | Vizio L32 32 in. LCD HDTV
U-verse remote code for a Vizio HDTV
1343 is the closest one I've found that works, it will turn the TV off and on, control the volume, and enables mute. The only other thing it doesn't do is change the video input, I'm still working on finding that. If this helps, please give me some kudos.
Nov 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Coby TF-TV3217 32 in. LCD TV Logo
116 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
