Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp LC 37 D6U
No sound from any input, speaker pops when turned on. It has worked for 8 months, but started to act up. turning the tv on and off worked for a while, but now there is no sound i own a lc37d62u. When you turn the set on and off, it makes a popping noise. Sometimes the sound goes away and if you allow the tv to cool down by turning it off, the sound returns.
    Sniper:
  • 53 Answers
That popping noise means the silicon grease underneath the audio ic has melted and is shorting the audio. This is unfortunately a design flaw by sharp. To fix the problem, you'd have to disassemble the entire TV and clean off the melted residue off of the AV Board and replace it with a new Sharp Heat Insulation Pad. Its a pretty difficult job, I suggest calling your local Sharp authorized service center to fix that for you.
Posted on Apr 08, 2008
Sharp Aquos 37" LCD TV sound quit
You could open up the TV and look for signs of burnt components then try to replace the components or try to find a replacement for the entire affected board on ebay or something. If you can find out what the problem is maybe the service person will lower there price. $600 does seem very steap, it should be something closer to $60 an hour with maybe the first $60 as an estimate.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Feb 13, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No sound on Sharp Aquos 37' LC-37D4U
Almost all intermittent audio or audio failure problems with Sharp Aquos LC**D4U, LC**D5U, LC**D6U, and LC**D7U televisions are the result of a relatively simple design flaw involving the heatsink pad compound used on the Tripath TA-2024 amplifier chip (IC2502) found on the A/V board. This compound has a fairly low melting point and, over time, tends to seep out from between both top and bottom heatsinks onto the legs of this chip as well as onto circuitry immediately surrounding it. Further, over time the seeping compound also becomes somewhat conductive creating bridges which short the audio amplifier circuit causing everything from intermittent audio to complete audio failure.
Fortunately, in almost every case audio can be completely restored by cleaning the old compound from both top/bottom heatsinks and from both sides of the PC board in the area immediately surrounding the chip (I used rubbing alcohol which worked quite well). Sharp has issued a service bulletin addressing this issue (LCDTV-194) wherein a ‘2502 Heat Kit’ is specified. This kit is Sharp Part Number: PSPKIT663WJZZ and is available from circuitcity.partsearch.com for $19.95. However, it’s entirely possible to get by with the heat pad only, Sharp Part Number: PSPAZA663WJKZ for only $9.95. Please note that board replacement for this problem is almost never necessary, so if you’re working with a repair technician be sure and insist that he/she be certain to try cleaning the old board and replacing the aforementioned heatsink pads before charging you for a new board.
If one is reasonably familiar with electronics disassembly/reassembly and is willing to take their time, this can even be a DIY project. It is possible to find ‘important service references’ by simply entering LC26D4U (the 5, 6, and 7 series are very similar, and this information covers all screen sizes) into the search field at eserviceinfo.com. This will greatly aid in disassembly/reassembly of the TV, as the A/V board is somewhat ‘buried’ under other boards. Please refer to post # 373 at avsforum.com/avs-vb/showthread.php?t=647174&page=13 for pics of the information detailed here.
Particular thanks are owed ‘Aureius’ of the AVS forums for his research efforts concerning this issue !
Jan 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Nov 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Call Sharp. They are fixing my 18 month old LC40C32U for free.
Jun 10, 2008 | Sharp Aquos LC-32D40U Television
When I first bought my Sharp Aquos 42 inch TV...I started having sound problems...turned the volume way up to 60 maximum and could hardly hear it.
Then after the TV was on for 4 or 5 hours, there would be crackling chirping popping noise. It seems after the TV heats up for awhile...there is MAJOR sound problems.
So I was advised to buy a Sony surround system and connect it to my TV...deactivate the TV volume and use ONLY the surround sound. I did that...but the surround audio cables are connected to the back of the TV and I get the exact SAME problem with chirping and crackling sounds after the TV heats up.
SHARP IS NOT BEING HONEST WITH CUSTOMERS.
There should definitely be a RECALL on the sound board.
Replacing it does nothing....the overheating of the TV just damages the new sound board and the TV has to be repaired again and again.
Sharp LC 37 D6U
When you turn the tv on, do you hear a faint “pop” noise from the speaker? If so, the problem is with the heat sink under the audio IC. Over time, the heat sink will lose its consistency and start to melt, thus shorting out the audio circuit. To fix, you’d need to clean off the melted residue on both sides of the audio IC as well as replacing the heat sink with a newly redesigned Sharp Heat Insulation Pad. It’s a pretty complicated fix, I suggest calling your local authorized sharp service center to fix this problem. The part is inexpensive, so you’re most likely looking at a labor charge (maybe around $200ish) for the repair if they are not marking up the price too much.
Sep 04, 2007 | Sharp LC-37D6U 37 in. LCD Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
326 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
