Question about Husqvarna 450 e-series 18" Chain Saw
I bought a new 450 x chain saw this past march, How do you adjust the automatic oiler??
    Brigadier General:
  • 4,088 Answers
The owner's manual should disclose the adjustment detail. Set it so that the bar tip throws off a thin line of oil onto a piece of cardboard after a few moments of running at speed. Good luck!
Posted on May 28, 2010
Where is the adjustment for chain oiler?
depending on the saw it may or may not have one. most home owner saws are not available with an adjustable oiler. if however you are sure it has one it is accessed via the bottom of the saw on the clutch side
Feb 10, 2013 | Garden
How do you adjust the oiler on the husquavarna 450
The standar 450 does not have anadjustable oil pump, there is an optional adjutable pump if you wish to fit it.
Aug 18, 2011 | Husqvarna 450 e-series 18" Chain Saw
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Bar & Chain combo interchange
A longer bar will allow you to cut larger trees easier but if you don't need to cut larger diameter trees and just want to cut faster you can get a more aggressive chain but use caution as you should be VERY experienced as the chain has the ability to pull you right into the work if you are not careful! Using a very aggressive chain should only be done by professionals with full safety gear.
Jul 31, 2010 | Husqvarna Chain Saw 18" 450 Model...
How do you make the chain oiler spit out more oil? Its a husqvarna 450.
There is an oil-volume adjustment screw located near the chain return area either in back, or just under the case. Turn it CCW to increase volume. Hope this helps!
May 12, 2010 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Chain sprocket won't turn on my 450e series chainsaw
The most common causes are the chain is to tight or the chain brake is triggered.
Page 15 discusses how to check oiler operation and page 17 discusses both chain tension and the chain brake. You cannot check the oiler if the chain cannot rotate. (you provided no serial number, this may not be your saw Feb-2008)
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_1151081-96.pdf
If this is not the problem or you have additional questions please reply below. I will get back to you.
If I chose the incrorrect manual you can download the right one here:
HusqvarnaUSA.com
06 1500198
HTH
Lou
Feb 13, 2010 | Husqvarna 450 e-series 18" Chain Saw
How do i adjust the bar oil
turn the saw upside down, there is a little screw that only turns a quarterturn, turn it counterclockwise for the maximum flow
Nov 25, 2009 | Husqvarna 450 e-series 18" Chain Saw
Husqvarna 450 e-series 18" Chain Saw Logo
384 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
