Question about HP LaserJet 3050 All-In-One Printer
Black line is printed on the right side when copying or faxing
  • 241 Answers
This could be caused by a faulty cartridge or a build up of toner on the drum or fuser. Toner can also be on the rollers causing line to show up on the prints. Try first replacing your cartridge to see if the line clears up if not have your printer cleaned by a certified technician.
Posted on May 28, 2010
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
My Brother Intellifax 4100 sends faxes that appear with a solid black line on the side--i think it's the right hand side. It prints copies the same way. How can I fix it?
if the faxes going out have the line but coming in print out clear then the glass at the document feeder is dirty and probably needs cleaning.. check under the feeder cover and look for a glass piece where the documents go in this picks up dirt and typex and when it scans the document it thinks its on the original.. a soft cloth and some glass cleaner should clean it off..
Jul 11, 2010 | Brother IntelliFAX 4100 Laser Fax
95% of copy or sent fax black
You need a new cis unit, that is the scan assembly. Some of the pixels are burned out. Exposure settings won't help at all...
Jul 24, 2009 | Brother IntelliFAX 4100 Laser Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Same black line on right side problem
take out your drum unit and make the blue plastic corona wire cleaner on the drum unit is pushed all the way over to right side. see if that helps.
razors
Dec 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Black streak on one side
Stop the print with a little practice, half to 3/4 of the way threw machine by opening door at right time. You want the paper to be jammed/stopped after the drum (has image on paper) but before fuser (print should still rub off)
fuser is blue green 300 thingy
If print is line less where stopped then mark is from fuser, replace
If print has line before fuser then it is drum/cartridge
..probally drum..need more info to know for sure, ie you say mark when faxing I guessing you mean receiving, what happens in copy mode is same as printing I'm assuming too
Nov 08, 2007 | Canon imageRUNNER 1370F All-In-One Laser...
Printing problem
Before we can diagnose the problem, we need a little more info.  Do the internal prints (TX/RX report) also print the line, or only copies?
Oct 16, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
HP LaserJet 3050 All-In-One Printer Logo
151 people viewed this question
Seeker5211
Seeker5211
