Question about Maytag Refrigerators
Ice maker doesn't work. It slowly died.
  • Maytag Master
  • 909 Answers
Take note how full the ice tray gets with water after it has dispenced. If water is low, defrost freezer and it will allow water in pipr to also thaw out. Fairly common problem. If water is full that is another problem. Normally to save a lot of time, the unit is replaced.
Posted on May 28, 2010
Ice maker doesn't make ice. It seems to not being able to rotate the ice tray to dump the ice.
this may be a bad heater in bottom of ice maker . if so replace the ice mker .. but do ck the tempts ..freezer must be 15 de or lower for ice maker to work properly .. hope this helps mm .. feed back pls ..
Jul 10, 2011 | LG LMX28988
Ice maker will not make ice
It sounds like you might have a bad fill valve. There are several reasons that an ice-maker doesn't get water. If the freezer isn't cold enough, the ice-maker thermostat will not allow it cycle. There are two different styles of ice-makers. Pull the white cover off of the ice-maker, if you see two gears the you have one of the earlier models. Turn the smaller of the two gears counterclockwise slowly until the gears start to turn by themselves. Now if you do not have the two gears under the cover, then you have a modular ice-maker. There are several holes in the brown plate. Each hole will have a letter beside it. Jumper between the T and H holes until the ice-maker starts to turn by itself ( you should hear a click if you'll listen closely). Now that you ave cycled the ice-maker, check and see if there is water in the ice tray. If you still have no water then change your fill valve. If you do have water then its usually cheaper to replace the actual ice-maker. Be sure to check the temp of the freezer, most ice-makers will not cycle above 10F degrees. Most ice-makers are around $130. Most valves are around $50. I hope this helps you solve the NO ICE situation. Thanks for using fixya..com , please let me know how it goes, thanks mike
Jun 06, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker has stopped making ice. Infa-red light on inside doesn't seem to be working
One of the causes of ice maker not producing ice is a bad solenoid valve allowing water to pass by and causing the water line to freeze inside the freezer. In other words, if the valve is not holding very well, it will allow water to pass in the line that supplies water to the ice maker. A small drip will ensue and slowly freeze in the line and eventually turn into an ice plug that will prevent water from filling the ice tray. Thawing out the freezer will not solve the problem, you will have to replace the solenoid valve.
P.S.Test the solenoid valve coil and disconnect the line from the valve to verify that it is not allowing water to pass when not energized. Test the infra red module according the manufacturer's instructions if you have them at hand. If the solenoid valve is good and the infrared sensor system is bad , replace it (Infrared system) . The ice maker should be the last part to consider for replacement at this time.
May 06, 2011 | Refrigerators
GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker is not working, and refrigerator is not getting cold
Order Ice Maker
Refrigerator Parts
Nov 21, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Ice maker dripping slowly at right front corner, thus causes the ice to freeze into slabs in bottom of ice bucket. What do I do?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool side by side GS5SHAXN. Ice maker slowly died.
Hi agcruiser;
Have your change your water filter lately?
If not try that, as it may be starting to block up a little.
Another problem could be the water inlet valve(Ice Side) situated at bottom of fridge, that could be starting to wear (Can interchange with water side inlet valve). Yes there are 2- 1 for ice and 1 for water
The Whirlpools Ice Michine set up is very easy, and runs by a mechanical system, they can be tested (Use a qualified tech).
Cheers hope this helps
Mar 29, 2010 | Whirlpool GS5SHAXN Side by Side...
Ice maker makes ice really slowly
perhaps there is not enough water being brought to the ice maker from the inlet valve. you may have to change the valve.
Oct 24, 2009 | GE GTS22 21.8 Cu. Ft. Top-Freezer...
Water wont go all the way into the ice maker
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Oct 08, 2009 | Kenmore Refrigerators
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
Refrigerators Logo
51 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
