Question about Delstar DS 31024 MP3 Player
Starting error My son removed battery now it just displays "Starting" on the display.
    Problem Solver:
  • 6 Answers
After it displays starting press press play again and it should be turned on.
Posted on Apr 08, 2008
Can some one help me my step son was playing with his iRULU tablet while it was charging and it has gone black and when you turn it on you can hear it and you just can't see it what can I do to fix it
Shine a flashlight on the display while it is running (I assume a game, anything is ok) if you can faintly see the display working then the backlight has failed on the display.
Otherwise - try resetting it, removing the battery(if you can) and then giving it a full charge.
Goodlucj
Jun 13, 2016 | Tablets & eReaders
No screen on starting laptop
remove the battery from bottom, plug into ac power pack, and try it that way
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Tip
SOLUTION FOR SHARP XEA 203 DISPLAY IPL error
most machines have this problem.I have solution for it.
first, machine turn on and remove batteries one by one. then machine display no battery.
replace battery one by one again machine display ***MRS***
press CL Key. error is didnt apper again.
but your data is lost your company name,tel number like.
programme data again.
on Sep 01, 2010 | Office Equipment & Supplies
Electrolux split A.C. display F6 error and trips immediately after starting the compressor.
Anti high temperature protection.
Check the outdoor coil for airflow obstructions.
Check the outdoor fan motor for correct operation.
May 23, 2016 | Electrolux Heating & Cooling
Video display driver stop working and blue screen appears while running and also does not start
Try Cold-Start, shut down, unplug, remove battery, hold down on/off button for 10 secs, replace battery, plug in push on/off button try to start normally. If that fails try starting in safe mode to troubleshoot error.
Nov 04, 2012 | HP Pavilion Computers & Internet
Display reads sonar timed out
check the battery voltage as low voltage can cause the unit to display errors and prevent the sonar from starting up. This unit is more sensitive to low voltage than many other electronics. If charging the battery or replacing it with a known good battery doesn't work then contact garmin for a replacement of your fishfinder.
Nov 18, 2010 | Garmin Fishfinder 400c With Dual Beam...
I own a TI-83 Plus that just quite one day. I replaced the battery and still nothing. The display never recovered. Between my son and daughter and I this is the third TI-83 Plus that has had power circuit...
When you change the batteries the display reverts to default setting. My optimistic guess is that the screen display is so light that you cannot see anything on it. This can be arranged.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. Whileholding [CLEAR], reinsert the AAA battery and then
  4. turn the calculatoron.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cables ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. Whileholding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
If all else fails you can contact Texas Instruments at ti-cares@ti.com
Hope it helps.
Thank you for using FixYa.
Nov 19, 2009 | Texas Instruments TI-83 Plus Calculator
Xerox Workcentre C226 - Error H5-01
This might help, but I don't know how to put it in tech mode.
"The fuser error reset code will reset the machine so it will run after the problem is fixed.First remove any jam in the fuser then enter tech mode;
press program, * ,clear, * enter 1 4 press start then turn machine off and then back on."
Jul 29, 2009 | Office Equipment & Supplies
The Lego NXT controller has no display
Instructions for repair of a Lego NXT Brick with no LCD display:
http://blogs.wsd1.org/etr/?p=495
-Wayne
Nov 26, 2008 | Lego Media Lego Mindstorms
Delstar DS 31024 MP3 Player Logo
Top Delstar Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Mister Danger
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
