Question about LG RH1777 DVD Recorder
Silly machine will not pass 'hello' screen! Will not allow me to eject DVD and is making a mysterious ticking noise! Has rendered the whole unit useless.
  • 105 Answers
Hi its very easy, if you press eject and if it is making some motor sound then just replace loading belt
Posted on May 28, 2010
Grundig GR1000 DVD won't eject. Motor makes whirring noise but no action.
It could be either a gear or belt driven motor, you need to remove the top cover to check. If it is belt driven you can replace the belt make sure to take the sample with. If it is gear driven you need to replace the whole carrige unit.
Jun 02, 2011 | Grundig GR-1000 DVD Player/VCR
Navigation not working get disk reading error message upon starting car and every few minutes afterward
Check for a scratched or dirty Navi DVD disc. Clean or have the scratches polish out at your local game store. Video game stores usually have a disc repair machine that polishes out scratches.
Note: In some cases the Navi unit can cause rotational scratches on the DVD. If this is the case than the Navi unit will have to be replaced.
Oct 05, 2010 | 2003 Honda Accord
Powers on wont post but dvd rom
Eject any disk from the DVD device.
Turn the computer off.
Disconnect the "data" and/or the "power" connectors from the DVD-ROM.
Turn the computer on, and see if it starts when the DVD-ROM is not part of your system.
If it starts, then your DVD-ROM needs to be replaced.
Dec 08, 2009 | Medion Computers & Internet
My Disk drive door won't open up to allow my to install my disk. It makes the clicking noise like it wants to open it up - how do I get it to open?
try to see if the cd/dvd drive would eject if you are outside of Windows. you can try it in the bios screen. to go there, restart your computer, then on the DELL logo, continuously tap on F2 key. once inside the bios screen, press the eject button of the cd/dvd drive.
Oct 10, 2009 | Dell Dimension 1100 PC Desktop
Player will not eject disc
Generally this is caused by the software in the machine being poorly programmed and has developed a bug. Try unpluging the device for 24 hours to dissipate the charge and plug it in again. This should reset the software and allow you to eject the disc. If this doesn't work, it is a hardware issue and the device needs servicing or replacing.
Aug 20, 2009 | Apex Digital AD-1110W DVD Player
Cannot eject DVD or turn off machine or anything
hold your power button down for 8 seconds and the machine will power down
Feb 19, 2009 | JVC DR-MV5S DVD Recorder/VCR
Go Video DVD will not eject
this suggestion made on this forum worked great for me.
I don't care if it does sound silly.. smack the unit smartly over the eject tray when you press the eject button.
Dec 23, 2008 | GoVideo Go Video DVD/VCR Combo
My poloroid tv with dvd player dvd player put dvd in makes noise
This is a very common problem with the 32" TDA-03211C TV/DVD combo unit. Poloroid sent me three replacement DVD units in the first year and each began doing this same thing after a few months (chunking noise and could not load disks). Finally my warranty expired and it failed again. I ended up with two units left after all those exchanges, so I took one apart to see if I could figure out what was going wrong.
In switching the units out one day, I noticed that the forward facing side of the DVD box was getting very warm even when it is not being used. Also, the dvd's felt very warm when ejected from the unit. I also noticed that the metal plate which is behind the picture screen and only about 1/4" from the forward facing side of the DVD box was even warmer (about 110 to 120 degrees F). This heat is distorting the thin metal and plastic parts in the DVD unit, causing the parts not to be in correct contact and alignment (disk won't play and sometimes won't eject).
With the front and top covers removed from the DVD box and the box laying flat on a table (and no dvd in unit of coarse), I pushed downward firmly on the black plastic disk at the top of the drive, and also on the lever arm that is accessible through a hole near the left front of the unit until they bottomed out to bend them down some (the lever arm was warped upwards where it was actually rubbing the top of the case - that was the chunking sound I heard).
I then went to O'Rielly auto parts and bought a 1'x2' sheet of exhaust manifold gasket material for $8. This material is not flamable and will withstand temperatures that would melt this TV into a puddle. I cut the gasket material so that it would fit neatly inside the top cover of the DVD box (metalic side up), then put the top cover and front cover back on the unit. I cut another piece of the gasket material to fit snugly in the space between the forward facing side of the DVD box and the metal plate that is behind the picture screen (metalic side facing picture screen). I then reinstalled the DVD box into the TV. It was a little tighter fit than before, but went in OK and is still removable with some effort.
Both of the previously non-functioning DVD units I have play fine now in the TV. The disks eject perfectly every time now and I notice a significant difference in the temperature of the disks when I eject them. No more strange noises either.
These DVD units are fine and are actually quite well built, but they are just mounted too close to a heat source. A little insulation is all it needs. I cant believe Poloroid's design people can't figure this out.
Nov 16, 2008 | Televison & Video
DVD Stuck in player
There is nothing you can do with this problem unless you are able to repair DVD players, the loading mechanism of any DVD player is very complicated, chances are a small part has broken. Call the dealer and ask for the phone # of the repair center they use, call them for an estimate, don't go through the dealer, they will double the repair bill from the radio shop.
Oct 14, 2008 | 2003 Lincoln Aviator
LG RH1777 DVD Recorder Logo
166 people viewed this question
