Question about Frigidaire ATF6000ES Front Load Washer
We have an shirt that mysteriously got sucked under the drum. We can see it through the drain holes. How do we get it out? Can we take the drum out somehow - we don't see any screws and we don't want to damage the seal.
    Brigadier General:
  • 3,006 Answers
The drum cannot be dismantled so don't even try. What's probably happened is that a part of the garment slipped through the small gap between the inner and outer drums and then the rest got dragged through.
If the machine is still working normally and does not seem to be devouring other garments (always use a laundry bag or pillowcase for tights and underwear) then ignore it but regularly check the trap filter on the lower front of the machine. The shirt will eventually make it's way there and modern trap filters are designed to shred the occasional errant sock and to spit it out without blocking the machine. A shirt is probably too big, so when you find that the machine will not drain or pump out properly, disconnect from the mains, pull the machine forwards and tilt it back enough to reach the pump from underneath (for safety it's VITAL to securely prop the machine so that it cannot fall or slip onto you). A thick, often corrugated, flexible hose will connect the drum to the pump. Squeeze the hose and you'll feel whatever has blocked it. Unclip the hose, pull out the obstruction, and you'll be good to go again. You may even be able to use this method to fish the shirt out before it causes a problem by disconnecting the hose at the drum and using a bit of coathanger wire to probe into the drum and fish out the shirt. Careful though, as sometimes I get called out to folks who also have a coathanger wire stuck between the drums...
Posted on May 28, 2010
Whirlpool front load dryer - gives little holes in the tee shirts and other clothing's. Sometimes it feels like its burnt and sometimes its just holes and ripped
Check for sharp edges and pinch points on the ribs in the drum that tumble the clothes. I had my drum replaced under warranty.
Dec 14, 2016 | Whirlpool Washing Machines
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
Whirlpool Cabrio Top Laod Model # WED 7800XW I believe the washer ate my shirt. Is it possible that the shirt was sucked down into the tiny space between the agitator and drum in the bottom of...
Thanks for choosing FixYa and welcome to the site. It is very possible that this has happened. It wouldn't go through no drain hose but it can be at the bottom of the tub. Only problem is taking the washer apart tp get to that level.
Apr 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
May 10, 2009 | Amana NAV5800A Top Load Washer
Holes in clothes
Inspect the rubber seal, and steel drum to make sure there is no foreign object sticking out, which could be tearing holes in your clothes. Also check to see if any of the holes in the steel drum are dented in. or out or misshaped, as this could cause the tumbling action of the drum to tear clothes.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Sounds like a jet engine at full spin cycle
These things are notorious for sucking clothing under the the drum , it could cause it to be noisy spin slow and have drain problems . This is such a poor design . Try removing the drum and see if there is an article of clothing under it , mine sucked up a mans large shirt . Even if the drum seems to spin freely it still could be the problem .
Mar 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Holes in Shirts from LG Front Load Washer
This may sound weird but try using a slower spin speed.  The reason is because the faster the spin speed is, the more the clothes can get sucked through the holes in the drum.  On the other side of the drum that you don't see could be some metal points that can snag the material.  When you pull the clothes out, you will pull the thread that comes entangled with those metal points.
Sep 21, 2008 | LG WM2487H Front Load Washer
GE Front load washer clothes coming out with holes/torn/even shredded
Metal inside washer drum may be faulty and causing tearing of clothes (run your finger around the inside when empty and you will feel where it snags). Had same problem, only got worse and ruined many expensive t-shirts! Replacement of drum is required and is extremely costly if not under warranty!
Jun 05, 2008 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
104 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
