Question about LG Flatron L1750S 17" LCD Monitor
With power but it stop after few seconds
When cpuswitch on,my lg lcd monitor will switch on but after a few seconds it will switch off,no display but have power....
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L1750&kategoria=&kat2=all
Posted on May 28, 2010
Display Shutdown After Few Seconds To Few Minutes
Hook a spare monitor to the computer to rule out the video graphics card in the computer, and sub another video cord from the computer to the monitor if possible to check your LG monitor, If the display shuts down and power light changes colour or goes out it is a power supply board, one or more capacitors open causing the power to fail, sometimes the top developes a bulge making it easy to spot.
Apr 14, 2012 | LG L192WS LCD Monitor
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
My LG Flatron L1515S 15" LCD goes on blank scree(black screen) after displaying for 2 to 3 seconds and when i switch off and switch on monitor, again it is going blank after displaying for few second....
sitaramjava, Problem not new one!!! When lcd screen goes "black" point bright flashlight (torch) 1" (3-4cm) from lcd panel to determine if you can still see desk-top icons!!! If icons are visible, unit SMPS is in partial shutdown mode. If not visible then SMPS is in full shutdown mode. You or qualified CCFL back-lit lcd monitor technician will need to make repair to units internal SMPS/ CCFL inverter supply. Your monitor isn't any different than any other brand in it's basic design and operation!! Read my and other CCFL backlit lcd monitor technicians FIXYA profiles to see if you can repair it. 12fixlouie
May 04, 2010 | LG Flatron L1515S 15" LCD Monitor
Power ON, no display ,when switch off and on screen display for 1 or 2 second, again goes blank. model= LG Flatron -L1515s
check the power cords and the video connectors. if it's ok, then it could be a problem on video card
Feb 17, 2010 | LG Flatron L1515S 15" LCD Monitor
LG monitor display problem30S.
Do you have another monitor to try? If so, swap it out and see if you have that problem.
If the other monitor works, then your LCD monitor is going bad and must be replaced.
If the second monitor exhibits the same problem, then it's your video card that is the problem.
May 24, 2009 | LG Studioworks 563N 15" CRT Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
210 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
