Question about Troy Bilt Tb320bv Spring Assist Blower/Vac
I need the coorect spark plug size for a trou built blower TB320
  • 284 Answers
RCJ6Y Champion
Posted on May 29, 2010
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
Spark plug
Champion is the kind of plug. most are 5/8 of an inch.
Jun 14, 2013 | Poulan Pro 25CC 2Cycle Gas Blower
My 1340 evo 2 is sooting plugs casing misfire trou exurst and carb
Hi William, and the usual suspects are:
1. Plugs in bad condition, wrong type or number or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discarged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. If your bike has a CKP sensor you must leave both plugs in
head and check for spark with a 3rd plug. Good luck and have nice day.
Dec 27, 2011 | Harley Davidson Heretic Ag Motorcycles
Don't know if its a spark plug problem, need to need size of spark plug if needed for the blower?
look on the old one should be letters and numbers of the plug you need
Dec 16, 2010 | Garden
I need you to tell me wat number and type of spark plug to use for my 1997 nissan sentra car
NGK PLUGS GUYS AT PART STORE WILL HOOK YOU UP WITH THE COORECT PLUG PART NUMBER
Dec 15, 2010 | 1997 Nissan Sentra
I cant find the correct spark plug and dont have
go to a farm store near you take the old plug with you and match it up the size with a new one even you don't find the same number look for the one that is the same size.if you still have problems go to contact on Tecumseh.com
Oct 17, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
TrotBilt TB320 will not run with choke off
Drained the fuel tank and rinsed it out with clean fuel then filled with fresh fuel and unit runs fine now.
Nov 22, 2008 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Troy Bilt Tb320bv Spring Assist Blower/Vac Logo
293 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
