Question about HP Officejet 4315 All-in-One Printer
1. I'm not sure if I put the black cartridge in correctly. 2. I am in the Ukraine and I can't get the color cartridge until Monday. Can I use only the black copies or do I need both cartridges inserted for the copier to work?
  • HP Master
  • 4,737 Answers
I am confused when you concluded with the "Copier to work" since this printer is only a All-In-One inkjet printer. If you mean you are gonna make photocopies with this then I am sorry. And yeah you can do it without the color ink, but you should not remove it, otherwise, it'll ask you to insert the cartridge. You print/make copy with the black cartridge only. Replacing your cartridge is easy, you can refer to this tutorial if you are still confused, there's a flash presentation for you. If your printer model is Hp OfficeJet 4315 All-In-One Printer, this is exactly what you can do http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00620122&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=1138342 I hope this helps you. If you want to know more about how to refill inkjet cartridge, please let me know. I can directly you to the tutorial link. Good luck. Thank you for using Fixya.
Posted on May 28, 2010
Ink jet cartridge
  • 1 Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
  • 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
  • 3 Wait a moment. The cartridge carrier will automatically disengage.
  • 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
  • 5 Carefully pull the tape off the new cartridge.
  • 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
  • 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
  • 8 Close the printer's lid. Print a test page to ensure everything is working properly.
  • Hope It's resolve all Your Printer Problem,
    Or Still having Problem Then follow Us For
    Canon Printer Support
  • Apr 22, 2014 | Canon MX340 AllInOne InkJet Printer
    Tip
    How to refill the INK Cartridge ?
    How do i refill my INK Cartridge ?
    There are 2 distinct method
    1) Black has a bladder
    2) Color contains sponges - we need 3 sirenges with needle
    to fill the Color cartridge with sponges - simply punch
    COLOR CARTRIDGE
    1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
    You may need to pry plastic top or hole cover off using a thin metal blade.
    please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
    2. Using the picture(on the cartridge which shows you the 3 differed colored spots), fill syringe with the corresponding color ink.
    3. Insert the syringe into the correct hole of the color being filled and push all the way down.
    Notes : You will feel resistance as there is a sponge inside.
    So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
    If this happens simply draw back on the syringe a little.
    4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
    8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
    BLACK CARTRIDGE
    1. Fill the syringe with approximately 20ml of black ink.
    2. Push the syringe all the way into the filling hole and SLOWLY inject all the ink into the cartridge or until the reservoir is full.
    3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
    4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
    on Jan 04, 2010 | Office Equipment & Supplies
    Finding compatible upgrade to cpu 870
    Instructions
    5
    6
    7
    8
    Jan 10, 2013 | Dell Studio XPS 8100 PC Desktop
    Chsnge ink cartridge
    Hi there!
    Here's what you can do to change the Printer cartridges.
    1. Make sure that the printer is turned on. Turn it on if it's not.
    2. Open the printer cover, then wait until the carriage is idle.
    3. You will see the Tri-color & the Black cartridge. The tri color cartridge is the green one which is on the left and the Black is the one on the right.
    4. Press down the Cartridge you want to replace you will notice that it will be released from the cartridge holder. Once it's loose slide the cartridge out.
    5. Make sure that the correct Genuine Hp Cartridge is what you have. For your printer HP PSC 1610, HP 94 will be for the black and HP 95 is for the tri color.
    6. Open the cartridge package. Remove the protective tape. Make sure that you do not touck the copper colored contact and nozzles.
    7. Hold the print cartridge with the sticker facing up and the copper colored contacts facing the printer and slide it into the cartridge.
    8. Use your thumb to push the cartridge all the way in. You may need a little force to make sure that the cartridge has been installed securely.
    9. Once installed close the cartridge cover. Make a copy to test.
    Hope this helps!
    Jun 17, 2011 | HP PSC 1610 All-In-One InkJet Printer
    I changed two colour ink cartridges on my Canon iP4200 printer. Now it won't print colour. The pattern check does not print any colour.
    You might want to double check to make sure that your printer takes two color cartridges? If I remember correctly, the Pixma takes one black and one color cartridge? If you put a color cartridge in the black ink assembly that would cause it to stop printing.
    Double check and make sure that you have one black cartridge in the correct place and one color on the other side.
    Apr 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
    How do I open my canon printer to change the ink cartige?
    Step 1
    1. Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
    2. Step 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
    3. Step 3 Wait a moment. The cartridge carrier will automatically disengage.
    4. Step 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
    5. Step 5 Carefully pull the tape off the new cartridge.
    6. Step 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
    7. Step 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
    8. Step 8 Close the printer's lid. Print a test page to ensure everything is working properly. ....plz give feedback..
    Nov 15, 2009 | Cannon Canon i960 Photo Printer
    Hp psc 750 won't print with new color ink cartridge
    To solve the printing problem..
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer.
    Hope this help. Please Rate My Response! Thanks!
    Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
    Print cartridges
    1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
    2. Lift the top cover to the open position until it locks securely into place.
    3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
    4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
    5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
    6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
    Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
    21 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
