Question about Dishwashers
Hi :) Hope you can help. I have a double drawer fisher & paykel dishwasher. In the middle of the night a couple of weeks ago it started up making very loud whirring noises. We could not turn the power off, my flatmate who is an electrician had to remove the fuse to get it to turn off. We have never had problems with it previously. Is this common? Pls help. Thank you. Donna.
    President:
  • 2,651 Answers
Sound slike it has detected a waterleak, this particular machine has a sensor o nthe bottom of caibnet , that when water is detected, it automatically powers up and turns on the pumps , it will stay on unitl the water dries up and/or you shut off the power,As fasr as common problem,, welll the fact it s doing what its doing is common, but why is the water on the flkoor is the real issue and that can be a few different issues, if your able to remove the bottom drawer from the tracks it slides put on there is a tech sheet glued to the back walll behid the lowwer drawer, thers is a pretty good walkthrough trouble shooter as well as somre god diag tricks and tips
Posted on Apr 08, 2008
SOURCE:
Fisher & Paykel DD601v2 dishwasher
here's the manual..
i did not read thru the whole thing but there are quite a few removal items that i'm sure will lead you to drawer removal.
Hope this helps you.
https://www.scribd.com/doc/6462163/DD601V2-Manual
Jan 22, 2018 | Fisher and Paykel Dishwashers
The dishwasher will start for two sec and then they both stop and a red light comes on and starts beeping with motors running.
This indicates the flood switch has been tripped. The video in the link below explains how to access and repair single and double drawer fisher and paykel dishwashers. Its a really good Fisher Paykel dishwasher repair video it really helped me.
Fisher Paykel Dishwasher Repair Video Link
Mar 09, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have the Fisher & Paykel single drawer dishwasher ds 603 and put it on a normal cycle last night. It started as per normal and sometime during its cycle it stopped and the drawer now seems locked. ...
It is very likely the thermal fuse has blown or the power supply board has had it. Either way the power to the controller and the drawer lid seal motors is cut off. This is why the drawer is in locked state as the motors have seized.
You have no choice but to force open the drawer to get access to the affected parts. Make sure the mains power to dishwasher is turned off as the base will be live.
Replacing the power board is easy but if the thermal fuse is blown then you are up for a large cost as it is integral in the heating element.
Refer this document for details of parts and location. Heater is item 17 on page 18 and powerboard is item 15 on page 13. (the document is for double drawer model but it just doubles up on parts)
You can get a rough idea of the parts cost from this site. Depends where you live.
Hope you are able to get it fixed.
Jan 27, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do you remove the drawers on a fisher & paykel 2 drawer dishwasher please
Open the drawer, on both sides, near the front there is a small circulat pin, with a slot in the middle, grab the middle with a pliers, and pull straight out, with this out, the square button in front of the hole will push in, and slide it slightly back, then the drawer will slide out, and you can lift it off the rails.
Nov 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel M#DD603SS - While not running F1 repair mssg
Actually the part is called a Link Actuator. There is one for the upper drawer and one for the lower. When the drawer is shut, it will actuate and the dishwasher will lift the drawer up against the upper lid. When the actuator is broken, this will trigger the flood switch which inturn triggers the F1 code. In the meantime, when the dishwasher is turned on, the water will shoot over the side walls of the drawer and get down below to damage the terminal block module.
Jun 21, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Fisher paykel dishwasher double drawer
Download this manual from Fisher Paykel and examine the parts list for a hose joiner ( mergese two into one) This link provides you with contact information from the manufacturer but if you have a Lowes department store nearby, they carry that brand and can probably get you the part you need...
http://www.fisherpaykel.com/dishwashing/index.cfm?productUid=41320F55-BAF2-B7E5-DA33A5CE6070C7EC&section=supp
Also: Have you tried contacting the place that sold it to you for a replacement? They may be your best bet...
Hope this helps you..
If it does, please rate my response accordingly.. Thanks
Oct 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel twin draw
I'm not really sure. With the double drawer configuration, I know the top drawer is larger than the bottom drawer. If I had to take a guess, I would say the single drawer might fit in the top of the double drawer.
Jun 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Dishwashers Logo
117 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
