Frigidaire glws1233as1 water runs continually. seems like a valve is stuck open or something. water is draining as fast as it is filling up.
  • 166 Answers
Your drain hose or drain is too low causing water to siphon from the tub as fast as it runs in. raise or loop the drain hose higher than the highest level of the tub.
Posted on May 28, 2010
Testimonial: "yea, i hadnt noticed but the drain hose had migrated down the 'stand pipe'. it seemed too simple an answer, but once i pulled the drain hose back out, it worked as advertized."
We lost electricity very briefly today which caused the dishwasher, washing, drying, clean buttons to blink when the electricity came back on. I opened the door to do a load of dishes hours after the...
it seems unit fill valve is stuck open and water is coming in even when machine is off.fill valve opens up only when u start the unit.2 chks this u can open the door and look at the hole inside from where water comes in.if water is coming in with dooe open then 4 sure valve is bad and needs 2 be replaced.
Aug 11, 2009 | Frigidaire 24 in. PLD2850 Built-in...
The water is going out the drain and cannot fill up the tub.
Check out the height of your drain. If the drain is too low, the water will drain right out of the tub. Check out the attached photo. Hope this helped and best wishes.
Aug 02, 2009 | Roper RAS8445KQ Top Load Washer
DISHWASHER IS RUNNING BUT NOT FILLING UP WITH WATER
Your problem is probably the water fill valve is defective or it may be the drain valve is stuck open. If it is not filling with water at all, it is probably the fill valve. If it is filling as fast as it is draining, it is probably the drain valve.
If you need more help, post another comment.
Thanks,
Tim
May 18, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Dishwasher overflows when running and when not running still fills without draining
Check the water fill valve - sounds like it's stuck open. Turn the power to the machine off. If water continues to fill into the machine it's the water fill valve. If so...
Take the front lower cover off and look for the valve - it will have a water line going to it. This could also be caused by a bad control board, but look at the water valve first.
May 17, 2009 | KitchenAid 24 in. KUDS02FRSS Stainless...
Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
May 09, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Water drains out as fast as trying to fill
hello, have you checked to see if your drain valve is'nt stuck open ?
Mar 31, 2009 | Washing Machines
Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Mar 15, 2009 | Hotpoint 24 in. HDA3400G Built-in...
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag washer PAV2300 water over flow
from what I am reading on-line, it is the mix valve, aka water valve. Unplug the washer, then see if it still fills. If so, it's most likely stuck open, and needs to be replaced. about $22.00
Feb 21, 2008 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
