The barrel has stuck
My machine has been very noisy lately when spinning. This morning it finished a spin and then stopped, the barrel has stuck and cannot be moved.
  • 159 Answers
I dont know what brand of machine you have you didnt say so its hard to give advice but you either have a coin or other debris thats gone throgh the wash & has jambed the drum or the drum bearings have seized up.
Posted on May 28, 2010
Why do the cloths in the wash comes wrinkled when removed from the wash
There are different ways the washing is done by different people that is why there are a lot of options to wash on.
If you put your machine on in the morning and empty it when you get home from work or other then the washing will be stuck to the side of the drum after spinnig some time before, getting all creased up. If this is you, then you need to set the "Rinse Hold" this will stop the machine from doing it's final spin until you release it. Of course you can't put delicates on a fast spin or they will be rueined. Basicly, select the right spin speed/time for the fabrick and try and take the washing out of the drum as soon as the machine finishes.
Oct 01, 2014 | Bosch Washing Machines
Rinse and Spin cycle stuck and not rinsing or spinning properly
Just read your posting.Now just a couple of questions.Are you using a warm fill for the wash or cold?if are using warm try cold only and take note of the time it takes to fill.I don't think your cold water is filling properly. My manual says that with only the 1st rinse light working it is your control module that is faulty. Please try a cold water wash and reply back so we can rectify this problem.
Jun 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
When machine went into spin it was very noisey and the metal tub has rubbed agaisnt the plastic inside and caused A bit of damage were it rubbed but the rubber seal was not touched I have taken the back...
It sounds like the bearings have collapsed..You may have noticed a noisy spin cycle prior to loosness in the inner drum...This is a big job. Get quotes...Good luck...Nomess
May 20, 2010 | Washing Machines
When my zanussi aquacycle 1200xc is on the fast spin cycle the spinning drum seems to be getting noisier of late.
Probably the main bearings are going, spin the drum by hand, there should be little or no noise at all, if it feels rough, or noisy, then bearings are failing.
Please rate my solution.
Thanks.
Oct 10, 2009 | Zanussi F1245W Front Load Washer
Barrel will not spin, sounds like motor is running.
check the p-trap for stuck loose items---change,rocks,etc.. I had the same problem and the technician said the placement of the p-trap causes lots of loose items to get stuck, which causes the washer not to go thru its cycles & won't spin.
Apr 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Will not spin.
could be a couple of causes.First take off panel at back of machine and check that belt is in place.
Has it been noisy on spin lately?
Jan 29, 2009 | Hotpoint WMA64 Front Load Washer
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
Oct 13, 2008 | Hotpoint WMA76 Front Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
