Question about Gaggia Classic Espresso Machine
When making an espresso, it takes ages for the water to come out and when it does, the coffee is really thin with no crema. I have tried everything with the coffee itself, i.e. making a slightly coarser grind to see if that would make the difference. I have checked to see that the water comes out without the filter being in the machine, it comes out clear with no problems. HELP!! I miss my lovely gaggia coffee ...
  • lor158 May 28, 2010
    Initial problem ...
    President:
  • 1,902 Answers
Make sure that the seal on the coffee holder is tight and that it is not leaking any air or water. If this is happening or the seal is not tight enough then you will have this issue. The other would be that you are not packing the coffee tight enough and the water is running through it to easy. The last would be that the pressure is not high enough and you may need to change the purge valve on your unit to help the water come out quicker and with more pressure. This is a pretty common failure on all espresso machine, from the big ones that you find at the coffee shops to the smaller ones like what you own.
Posted on May 28, 2010
  • 506 Answers
Check and make sure the filter is properly aligned. Re-seat the accessories and try again.
    Hi Nicarta
    I'll try that this weekend, if it doesn't work, I'll write to you again.
    My email said you needed me to clarify my question ...
    Essentially, the coffee is coming out really slowly with no crema. I forgot to mention that it comes out only on one side of the filter for the first few minutes and only then does it come out to of both.
    I'll try to clean it though and can I also ask which descaler you would recommend for this machine.
    Thanks
    Lorien
  • Nicholas Enyika
    Nicholas Enyika May 28, 2010
    There so many good Coffee Machine cleaner outer there, but you stick to the accessories from Saeco & Gaggia.
    Thanks and best of lucks
Solis crema sl 90 the steem is not work
Usualy this a goggle steam wand. So you can insert a thin steel wire in the seam wand and turn the steam knob slowly untill you see some steam come out. Keep move the steel wire and after you get the first steam try to boil a glass of water and leave it for ten minutes and then boil it again. This will clean the steam wand internaly.
Sep 06, 2011 | Solis Crema SL-90 Espresso Machine
I just bought this Office Control model. I use espresso grind, softened water, and a heavy tamper. I fill the filter to within 1/8 in from the top, as advised. The espresso has a thin skin of crema,...
These two problems can be related.
If the water temp is low, You are NOT going to get a good extraction (almost no crema).
wait like 20 min. before using the machine, And if there is a pressure gauge (on the machine) it has to be in the 1 to 1.2 range.
Always warm up the portafilter/handle before use.
If the water is hot and there no crema, Adjust the grinder.
The group temperature is about 212f for commercial espresso machines.
Jan 14, 2011 | EXPOBAR Office Control Espresso Machine
No 'real' coffee taste or crema - despite following instructions
Set the machine for the finest coffee and the least water.
You should get a decent espresso.
For a regular cuppa, keep the settings the same and make either a medium coffee combined with a small coffee (jolt) or
make two small coffees.
I have this machine and the crema is nice at this setting.
Aug 01, 2010 | Miele CVA615 Espresso Machine
Need a new on/off switch-Solis Crema sl70-San Diego
Hi
Do you have a thick or thin switch? If its the thick one I have one.
Dec 27, 2009 | Solis Crema SL-70 Espresso Machine
I have a Krups burr grinder and I am wondering what setting I should use for the 800ESXL?
Really, this is personnal, but first you have to acheive an adjustment that makes your coffee possible to extract. Start with the coarser you can and reduce gradually. Do it one portion at the time, don't grind a whole bag !
The result should be a light hazelnut crema color, deep foam without hole in it.
If the crema is light cream color, the grind is too coarse.
If the crema is dark, uneven or runny, the grind is too fine, or you are using a wrong type of coffee (like only robusta, go for 100% arabica), or it's not toasted properly.
If the water doesn't flow at all, your grind is too fine.
It should take not more than 20 seconds to extract the coffee, if it's very short, grind is too coarse, if it takes longer, the grind is too fine.
Good luck,
JF
Oct 09, 2009 | Breville Die Cast 800ESXL Espresso Machine
Krups FNC3 Espresso Machine
If it's only 18 months old surely it will still be under some sort of manufacturers guarantee, you don't bin 18 month old coffeemakers nor should you be paying to fix them. Put the problem back in their lap.
Aug 01, 2017 | Krups Novo 3000 /FNC3 Espresso Machine
Sissling when making espresso
First of all, do you steam your milk first then immediately brew the shot? If so, that is your problem. When you depress the steam switch, the temperature elevates way past what is optimal for brewing espresso. If you try to brew immediately after steaming milk or using the hot water feature, that would definitely be why your espresso sizzles. Your shot will likely come out burnt tasting, thin and just plain rancid.
Either brew your shot first (learn temperature surfing for your best shots), or immediately after steaming milk, turn off the steam switch, depress the brew switch (without portafilter in place) for a few seconds until no steam comes out- only water (wait till you don't hear the sizzling sound). Hope this helps.
Aug 07, 2008 | Rancilio Silvia Espresso Machine
Silvia
there are two class of expresso coffée: one produce crema and the other none. A 9 sec shot, means you are putting ground coffee that are way too coarse. The Silvia requires coffee grounf extremely fine, near powder texture.
Hope this help
Dec 28, 2007 | Rancilio SILVIAespresso&cappuccino machine
UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Dec 16, 2007 | Rancilio Silvia Espresso Machine
Gaggia Classic Espresso Machine Logo
123 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
