Question about Video Cameras
Canon uc1 hi8 camcorder
Old school hi8 camcorder needing manual because the writing on the unit is in japanese.
SOURCE:
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Posted on Jun 21, 2008
SOURCE: Sony CCD-TRV96 NTSC Eglish user's manual
I Need Ur Help.
I have this Hi8 camcorder.
Is a old camcorder with japan menu.I need a english user manual for this model or similar.Thnx [email protected]
Posted on Aug 07, 2008
  • 107 Answers
SOURCE: Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Posted on Dec 04, 2008
  • 7 Answers
SOURCE: canon EX1
I have a EX1 Hi8 too and I have had the same problem. This camera is very old and it has a lot of capacitors inside that are leaking and drying out. They need to be replaced. This is a huge and difficult job and it makes no sense to repair. I did it anyway.
Posted on Jan 17, 2009
ginko
  • 19396 Answers
SOURCE: manual for camcorder/sony-hi8 camcorder-ccd-trv68
Try the link below:
Video Camera Recorder
Posted on Sep 08, 2009
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
Canon ES5000 hi8 camcorder won't load a tape.
that is the mechanism alignement(mode switch)
plus a little gear who match with the other
you will need a very good tech to fix it.usely its the problem.
hope that will help
regards Alan
Jun 02, 2010 | Canon ES5000 Camcorder
Canon EX1
Nov 03, 2008 | RCA CC6263 Camcorder
How do I transfer hi 8 tapes to DVD without the working camcorder
Greetings jamhere,
I have the same issue myself with my gillion of family tapes and my Hi8 unit broken! The only remedy I have found is to either invest in a new lower price HI8 unit, rent a unit and get my transfers done, or pay to have the old tapes put on dvd professionally. None of these options are too appealing to me, but really seem to be the only options available. If only HI8 had an adapter like VHS-C! I personally would look on some of the online resellers to see if you can obtain a unit that is lower priced to meet your needs. Investing overall in a Hi8 as your only camcorder is not advised, due to it being almost obsolete technology.
I hope this helps.
Thank you,
Dorothy
Go Ahead. Use Us.
May 05, 2008 | Video Cameras
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: [email protected]
Jan 05, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
8mm/Hi8/Digital 8
As this was quite some time ago, you probably already have your solution, but I just ran across this. Just in case you can use any other 8mm camcorder or deck if you can find one. Also if you still had it I would like to buy the Instruction manual from that old Canon ES780. Please write me back at [email protected] if you have it. Thanks.
Dec 14, 2007 | Canon ES870 8mm Analog Camcorder
Dec 06, 2007 | Video Cameras
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Video Cameras Logo
166 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
