Question about Robotoolz SelfLeveling Laser Level with Remote Control RoboLaser
Green light turns on momentarily, then nothing from unit
When i slide up the cover on the base unit to activate the laser, the green light below the laset window turns on momentarily, then nothing from the base unit. the laser wont go on, wont rotate. I did try the batteries.
  • 27 Answers
Make sure batteries are tight in unit ,making good connection there are many internal things that could be wrong no rotation could be bad drive motor broken belt bad pcb robotoolz now owned by bosch who owns cst-berger discontinued robotoolz lasers there is a guy who will give free estimate on repair A.P. Service & supplies 610-944 8030
Posted on May 29, 2010
Wont turn on
On all Panasonic Toughbook Models,
if the unit will not turn on try the following:
Step 1: Unplug the unit.
Step 2: Take OUT the Battery Pack.
Step 3: Plug-in the unit.
Step 4: Turn On the unit.
The battery pack acts like a giant capacitor and can
prevent the unit to turn on, especially when the unit
was previously used on battery pack and was allowed
to fully discharge to below 5%.
When the unit is turned on WITHOUT a battery pack,
then a single Green light should show on the front
edge of the unit when the cover is open facing you.
When the unit is plugged in WITH a battery pack,
then you should see a yellow, orange or green light
which shows the battery is charging. When the unit is
turned back on, then you should see two (2) lights,
one green and the other yellow, orange or green.
If the unit is plugged back in and either with the battery
in or out you see no lights whatsoever, then chances are
that something is wrong with your AC Adapter/Power Supply.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Feb 18, 2014 | Panasonic Toughbook Computers & Internet
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
How do I slide the green toner tabs?
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover (it is the full length of the cartridge holder).
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
When I press the power button to turn it on, it lights up green momentarily, then turns off again, and won't power up.
Please check the power supply unit. it is possible that the power output is less and so cut off when the power is activated.
Also it is possible there are errors in the main board and so when the CPU activates the power supply it encounters a SHORT and so cut off as a protection. if so remove main board and connectors to check by disconnection of circuits.
Mar 29, 2011 | Office Equipment & Supplies
Replace black PCU ricoh aficio cl3000
To replace the black PCU:
- Turn the printer off.
- Open the cover on the right side (as you're looking at the front of the printer).
- There are two green levers, one toward the front of the printer and one toward the back -- pull these out and lift the cover that they're holding all the way up (it should stay in place).
- Remove the black PCU by pinching the green lever and sliding the unit straight out.
- Take the new PCU out of the box, take off the tape around it and remove the cover on top of the unit.
- Align the new PCU along the rails the same way the old one was aligned (using the green arrow) and slowly slide it in. As you slide it in it will slide out of the bottom cover -- throw that cover away.
- Lower the PCU cover and slide the levers into place.
- Close the side door.
- Turn the printer on.
Mar 06, 2011 | Ricoh Aficio CL3500N Laser Printer
Where is the fuel pump relay?
Hello Charley.
The fuel pump relay is mounted under the hood, on the top of the left front fender.
It will be under a plastic cover and needs to be pulled out from below it.
There you will see two relays, one with a brown cover and one green. The green one is the fuel pump relay. The brown one is the computer power relay.
The computer test connector is there as well.
When pulling the connector off the relay, push in on the clip and pull firmly.
When you turn the key to the "ON" position the fuel pump relay should momentarily click on and then shut off. As soon as you crank the engine it should turn on and activate the fuel pump.
There you are as asked. If you need further help in locating it, please ask me here in a comment.
Thank you for using FixYa.
KL
Feb 09, 2011 | 1986 Mercury Grand Marquis
Drum error. slide green tab in each color
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover.
Oct 04, 2010 | Brother HL4040CN Laser Printer
Microsoft Wireless 4000 Mouse - No Red Light on Base
The red laser light stopped working on mine and it turned out to be the connetion between the battery tray and the circuit board. There is a metal tab on the circuit board and a matching one on the battery tray. When the battery tray slides in correctly the two tabs touch and viola (!), my red laser light came back on. Maybe one tab or the other got bent when I slammed the tray in crooked when replacing a battery- who knows.
Nov 01, 2009 | Microsoft Wireless Optical Notebook Mouse...
Brother printer mfc 4100 is printing light though the drum and toner cartridge have been replaced. Someone suggested that the laser is dirty..but I do not see how to clean it. I assume it is inside the...
yes mr it is problem your Lser unite laser mirror is dirty .please open your printer cover full body laser unite stand middle position open laser unite black cover and clean mirror tisupaper,laser drum unite six corner replactor mirror clean then solve your problem.If you are not success then toner unite ground point chach or ccd sensor clean
Aug 13, 2009 | Brother MFC 4100 Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Robotoolz SelfLeveling Laser Level with Remote Control RoboLaser Logo
693 people viewed this question
Top Robotoolz Measuring Tools & Sensors Experts
 Mikey
Mikey
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Robotoolz Measuring Tool and Sensor Expert? Answer questions, earn points and help others
