Question about Kyocera Mita KM-2550 All-In-One Laser Printer
KM2560 Panel dead
Hi there, I've got a Kyocera KM2560 or rather two of them now with a dead control panel. I have tried firmware and swopping the panels(complete with LCD, backight driver etc). After the swop I now have two dead panels(almost as if the mainboard blew the panel board). I have been intouch with the manufacturer directly and it looks as if I now need to replace the mainboard. Just wondering if anyone has had the same trouble or could offer some advice. I have attempted changing the USB route between the panel and mainboard. I have tried newer and older versions of firmware(both CF and USB).
Regards
  • 3 Answers
SOURCE: Grey shades coming all over the page as well in top back side of paper.
The Developer unit needs to be replaced. It gives background over entire page. If the printer is under 3 years old and is original unit (developer unit) you can get a new one free from Kyocera. Very good warr. from them. Phone number is 1 800438 6482 prompt 2 ; # for the part DV-62. Have your serial # and a status page with you. I work on Kyocera FS printers. Good luck. Russ
Posted on Dec 31, 2007
  • 3 Answers
SOURCE: i have a problem with kyocera fs9100
As for blocked, are you saying that the buttons wont acess the screen or is the display messed up. If it is locked it can be unlocked. Can you print out anything from it? Let me know, we work on the FS printers all the time. Russ
Posted on Jan 29, 2008
  • 523 Answers
SOURCE: Fixed IP adress problem
You can change it but it looks tricky, when scroll for the ip address hit go then use and up and down buttom to change it, you have to change the numbers too by using up and down buttoms after you finish, hit ok.
Posted on Mar 01, 2009
FixinFax
  • 3085 Answers
SOURCE: Kyocera FS1000+ firmware upgrade
Kyocera won't give it to you. You will have have an authorized Kyocera technician load it.
Posted on Jun 11, 2009
  • 3 Answers
SOURCE: our kyocera mita 3035 touch panel is not working.
Control panel problem
1-check connectors the input and if there is out put from the power supply board which is on right side of Main PCB and on the right side of fan
2-clean all the pcbs on Control panel,re seat connector
look for any piched wire/s
Posted on Oct 23, 2009
How can i fix error code cfb31 which appears on my kyocera km-4050 printer
Just generally CF-B31 firmware errors can be caused by a bad CODE DIMM, main board, or operation panel.
Try loading new firmware ...
Aug 21, 2015 | Kyocera Km-4050 With Feed, Fax, Finisher,...
Have a kyocera 2560 tried to replace the touch screen and there is nothing to see at the display could you please reply with advise?
Hi
Not being an engineer, I can't be specific about your problem, but you can get a full service manual for your machine relatively cheaply here:
Kyocera Mita KM2560 Service manual Parts Repair manual download
A description of the contents is given on this page and I also give it below:
"Service manual in English: maintenance, repair, troubleshooting, error codes, service mode, adjustment
Parts catalog: parts list, parts numbers, exploded diagrams
Service bulletin: Supplement manual, updates
Firmware"
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 30, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera service codes
It's a firmware mismatch error did you just replace the touch screen or the whole control panel
Aug 25, 2014 | Kyocera Km-4050 With Feed, Finisher, Bank,...
Kyocera error cf620
CF620
System Error. Error acquiring the event data. Panel detects CF000 as same error.
Reseat Memory, F-Dimm(s)and try another HDD
Jul 21, 2014 | Kyocera KM2560 Toner 20000 Yield - Genuine...
Kyocera km3050 error cfb33
This code means that the operation panel is not correctly communicating with the main board.Try turning the machine off/on.
It may require a firmware update in which case you will need to book a service call with an authorised Kyocera Service agent.
Dec 30, 2013 | Office Equipment & Supplies
System error cfb 30 kyocera 3060
CFB30 :
Incompatible Level Of Firmware on Main EEPROM.
May 02, 2013 | Kyocera Mita Toner 37085011 for DC-3060 &...
Kyocera km 4050 showing error code cfb31 how to clear it
hello,
This error has to connect the connector (red, green, white, black, black) in the wrong place in panel. yc1 - yc9
Apr 22, 2013 | Office Equipment & Supplies
My machine shows f 248 error
F248 is communication problem ,it some times happens when the printer cannot understand the data coming from the computer from certain program's or a specific file .reset the printer clear any print jobs on the pc and try print a test page if you're still getting that error you will need to get a service engineer to upgrade to the latest firmwarec
Jul 20, 2011 | Kyocera FSC2126MFP AllInOne Laser Printer
POST and BIOS Question: Dead laptop I`ve been given a Fufitsu Amilo L6825 laptop which is faulty.( It fails to get by the POST test so doesn`t even reach the BIOS option.(It switches ON, fans run but black...
Since you swapped everything, the last option will be the on-board power supply. If it has failed, then nothing will work. As a guess, I would assume the 1.8v power supply for the CPU has quit.
May 26, 2010 | Siemens Computers & Internet
Call Service F000 error
F000 is a panel communication error... update firmware... firmware as far as i know isnt available to the public... contact kyocera
May 07, 2008 | Kyocera FS-2000D Laser Printer
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
131 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
