Hi, our TV takes about an hour to 'warm up ' where one half or all four corners are black or too dark. We sometimes also get flickering horizontal lines across the Tv mainly from the right hand side. The TV is about 2 years old and the problems started about 3 weeks ago. Many thanks
  • mlynsey26 May 28, 2010
    I'll give it a go, thanks!
  • 6,993 Answers
this is an indication that your TV bulb is weak and due for replacement. Change the TV bulb and the problem should be resolved.
If you cannot change the TV bulb yourself, then consult a tech to help you out.
Good luck.
Posted on May 28, 2010
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
Just yesterday, my Panasonic TH-50PX75U HDTV Plasma Television has only the lower half displayed. The upper half "flickers" but for the most part, dark grey/black. wtf
There are several possibilities here. Four different boards are involved in the horizontal scan of a plasma tv. The most likely order of failure for what you describe is; SC board, Su and SD, and finally the SS. These are Panasonic's names for what are more commonly known as the Y Main (or Y-Sus), the upper and lower Y buffer boards, and the Z main (or Z-Sus). Sorry I can't boil it down any further for you,... would have to measure voltages, etc.
Jul 09, 2010 | Panasonic TH-50PX75U Plasma HDTV
Black Horizontal Line in Screen
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jun 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Zenith IQB32B42W 32" TV works sometimes but looses picture. Top half of picture goes blank (dark) and the bottom half scrambles into horizontal lines. I hear a pop or click right before this happens. The...
Capacitors can be deformed or some solderings on active components can be bad.
Amplitude change and image geometry want change when warming up, buy a canister cold spray and spray some components, Be careful when working at high voltages in the fly-back (horizontal) circuit by crt television, and tripler and Focusing voltage.
Aug 11, 2017 | Zenith IQB32B42W 32" TV
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony kv36fs76u
hi there, your set has a capacitor problem, most of it are on the horizontal section and video section., usually 100 microfarad electrolytic capacitor with a high voltage is damage. try to test some parts. ty
Dec 02, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Monitor took half an hour to warm up, now won't start.
doubtful this is a driver issue warm up is not needed for any monitor. this is a power board issue internal to the monitor capacitors or some issue on the main power board. let me kow what you will do. good luck.
Nov 18, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Flickering Screen
soon the picture going to go to black screen, you got somes capacitors bothering, you better to call a tech now that he can see the problem, later will cost you more..good luck ps the picture many times tell to the tech whats going on.
Aug 07, 2006 | Samsung HC-R4755W 47" HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
