Question about Goodman CLQ36AR49 Air Conditioner
I have a Goodman A/C unit model # GSC130361F A and a Evcon
The inside unit (Evcon) never shuts off. I want to know if this inside unit goes with the Goodman model GSCI130361F.
  • 420 Answers
The indoor fan should cycle with the outdoor part, make sure the thermostat is not set to fan "ON" and if the fan is on "AUTO" it could be a wiring issue or a fan relay that is stuck.
Posted on May 28, 2010
I'm trying find out if my old goodman unit was a
Hello WESLEY The unit mod# is 3 ton.If the inside part has an 048 number means together it produces 3.5 ton.If inside is 036 it is 3 ton together.If it is a split.If it is a package it is 3 ton.
Aug 02, 2010 | Goodman Heating & Cooling
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
Goodman model gmpn100-4 what does 3blinks on
Since most units do not have the same diagnosis,remove both cover panels and read diagnostics on the inside of the lower door.If it says flame sensor, clean it, with a dollar bill. Also, sometimes units will lockout. Shut power off for 10 or 15 minutes, and restart it. Good luck. If I had your phone number, we could do it a lot easier.
Feb 21, 2010 | Heating & Cooling
I have a Coleman Evcon Heat Pump Model DRH50481CB runs for a couple of minutes then shuts down.The pressure readings are good when it shuts down.If I wait for 15-30 minutes it will run and do the same...
Sometimes there is float switch inside. It open when you have stopped up drain. It could be tripping and slowly draining and bringing the unit back on. Check this first. Evcon did not put low pressure controls on there units. Could be bad capacitor also but check float switch first. Russ
Jul 19, 2009 | Heating & Cooling
Need to Know Where to Change the Furnace Filter
On the bottom of the indoor unit should be a cover or tray. Sometimes a large grill inside the house, close to the unit is where they are placed. Good luck
Apr 23, 2009 | Goodman Heating & Cooling
Carrier (outside) Coleman Evcon (inside) Air Conditioning question
transformer has just 4 leads. 2 for primary which is your 110 volts and 2 for secondary which is supposed to be 24 volts ac. if you splice the two secondary wires coming out of your transformer, you should be able to get a 24 v ac there.
the box that you are referring to could be a fire controller that in case of fire, it would shut off the fan and the compressor outside.
tnx 4 using fixya,
drcool
Oct 01, 2008 | Heating & Cooling
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Coleman Evcon model DGATO70BDC Starts to run then stops?
What you have is an ignition problem and your unit is shutting down on safety.
May 01, 2008 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
153 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
