Question about HP Pavilion dv6000z Notebook
Wont boot up
I had the same prob with boooting up,, i tried ur solution but it didn't work on me..i hope u can help me!! thanks!!
    Sergeant:
  • 209 Answers
Dear bebjirmav
usually a machine that refuses/ gets gobby on boot up has either a config error or hardware fault. Now the first thing i tend to do is whip out that hard drive (carefully though as the thing is fairly fragile) and plug it into a 2.5" enclosure and stick it into a PC's USB port. If the drive spins up and doesnt make any funny noises like whining, screetching, knocking, thumping or tapping noises, then its pretty okish.
Ok so your drive is ok then is it? good i thought so. Now we mov on.
Go on my friend, you can do it, you can clear that stubborn CMOS/ BIOS, and do this by taking out the battery.....yes i did say battery, and i meant the CR2032 watch type battery that is on the motherboard. this will certainly mean disassembling the machine to get at that round metal button shaped cell battery thats attached to the motherboard by a sprung retaining clip. JUST A WORD OF WARNING WITH THIS THOUGH....ALWAYS WEAR A GROUNDING STRAP AND REMOVE THE MAIN POWER SUPPLY BATTERY AND SUPPLY CORD FROM THE LAPTOP/ DEVICE BEFORE PROCEEDING. always stop if you dont feel able to proceed, and never feel afraid to get help from a techhie like myself (we are nice people that will always help). In addition, when you get to that battery, remove it carefully, and replace it with a BRAND NEW ONE in case the one you have either is a dud, or a bit leaky (can happen if you prise it out to hard or incorrectly with that slot head screwdiver/ extraction tool)
once you got that filthy battery out, you clear the CMOS my usually looking for three pins on the motherboard that may say either CLRCMOS, CLCMOS CMOS, CLRBIOS, CLBIOS, CMOSRST, RSTCMOS..... move the jumper to the clear position for 10-20 seconds, then put the jumper back in its original position or you will find you will be a lil stuck when you put the machine together and it dont work.
once you have done that, put the new CR2032 battery or replacement CMOS battery in, then rebuild your machine.
then go into your BIOS when you start the machine, either F8, F10, DEL, F2 or F12, and enable the most stable settings, and correctly adjust date/ time. then to exit you press F10 or save and exit. and then VOILA, YA DONE.
if this doesnt boot up now, then i think so you may have either a problem with operating system that needs re-installing, or you have a hardware fault elsewhere in the system. Anyting like a dud flop drive or a insulent optical drive can do this. even more so if your boot sequence is wrong, (this should be set to Hard drive, then CD/ DVD then flop, then LAN as default.
if no fault with operating system or peripheral drives, then your fault is within the motherboard layout (deceased CMOS/ BIOS or other critical component). CMOS/ BIOSes can be changed, but this requires extensive electronics knowledge and being very competent with specialist tools such as soldering irons and IC (integrated circuit) extraction tools. All of which if used incorrectly can cause damage to you and your system, so please be careful.
p.s.
can always try a firmware/ BIOS/ CMOS update, and do this by going to the manufacturers site and download the tool that will flash your BIOS, but ALWAYS READ THE README FILE and NEVER EVER FLASH YOUR BIOS WITH THE WRONG TOOL, YOU CAN AND ARE LIKELY TO KILL OFF YOUR BIOS/ CMOS (they dont usually recover when this happens as they forget their original identity and the motherboard literally "goes insane" beyond repair, unless you extract the IC chip and replace this with one of the exact type)
Anyway, good luck, and i hope this helps you, yours sincerely
oz
if you need any instructions on how to disassemble your machine, and the tools required forthis, then please do ask me, im here to help, i also have the guides on how to re-install and configure your machine
Posted on Apr 10, 2008
Elite g900 wont see cd/dvd at boot
Probably your CD/DVD are not in first secuence in booot. So, if you log in your bios, in boot secuance change it and select CD/DVD as first choice of boot.
Jul 02, 2011 | EliteGroup ECS G900 Notebook
Unable to reinstall XP after Vista upgrade
If u have win. vista installed in ur laptop than u cant install win xp............if u install win.xp than ur vista will b dissappear from boot menu
if u want to overcome this problem than buy a software VISTABOOTPRO
and install it in XP it will help u
OR u can ask me for free soft.....
Sep 12, 2009 | Compaq Presario Notebook
Insert disk in drive does not work, except with music cds which work but program disks do not.
hey 1st thing u need to know is "were is the problem" then u see how u can fix it.....the prob can be frome 2 things..frome cd rome itself or from ur operating system (assuming that u have already tried a copple of disks)....so try the cd rom on otha pc rather then urs...or if u cant do that putt ur windows xp or any other bootble disk and try to boot frome if it worked well then its ur operating system check the drivers (google)...**** remember "try the 1st solution 1st" gd luck
....and next time try to give more explanation bout the prob, u will be able to solve it fastre ;)....
Jul 02, 2009 | LG CRN 8245B (CRN-8245B) Internal 24x...
My battery died and i charged it but it wont come on
that's not the battery prob bro...check ur mob charging pins...i have the same prob with my MDA but when i squeeze my pins of MDA its working...so do the same...i hope this work...and also check ur friend battery on ur mob with charger..
Mar 04, 2009 | LG KU990 Viewty
Computer Wont Boot after Removing Display Chip
Sometimes when this happens to me there are several things that I try. Remove the memory module and reseat it firmly and then try to boot again. Most of the time, this is the problem. If not, then try resetting the bios.
Thanks,
Lolita
Feb 28, 2009 | Intel Motherboard
Boot problems
Often, this indicates that the laptop could not find its default boot device which would be your hard drive. Pls enter the BIOS/CMOS setup and determine if your laptop can auto detect the hard disk. If detectable, save and exit, if not the drive may require replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Doesnt boot from DVD rom
Hi
I know it sounds a bit odd but were u using a bootable disk to boot?
If yes, then try epgrading ur BIOS version it may help.
Jun 01, 2008 | Dell Inspiron E1405 Notebook
Problem starting my laptop IBM Thinkpad600E 2645
the boot has been corrupted... what did u install lately?? i mean before this problem occured... better use the recovery disk or original OS disk and do a system recovery...
May 22, 2008 | IBM ThinkPad 600E 2645 Notebook
Speaker Output
hi this is vijay , it is not ur speaker prob , it is ur music player prob, plz use k-lite codek pack 3.0. and i hope it will slove ur prob.
thanks
Feb 20, 2008 | Acer AV009 Computer Speakers
I mate
Ok ur prob is booting.....? I think u have extra storage card inserted in ur hand set so just remove the card and restart the system, it will boot. and if still the prob continues its OS prob, u should take it to the nearer i-mate service centre.
Jan 06, 2008 | i-mate JAM Pocket PC
HP Pavilion dv6000z Notebook Logo
114 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
