Question about HP Pavilion dv6000z Notebook
I broken a plug in a 2004 ford F150,the botton part of the plug is still in . the tread of the plug is out
  • hpsaffold Jun 02, 2010
    I had a broken spark plug in my F150 ford pick-up with a 5.4 engine. I have gotten all the plug out except the tail end of the plug, the part with the tread on is out.
  • hpsaffold Jun 04, 2010
    yes this solution was very helpful
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.com.
Please check the link bellow and go through the content thoroughly …
http://hubpages.com/hub/SPARK-PLUG-REMOVAL-INSTRUCTIONS--Ford--54Liter-3Valve-Engine
http://www.denlorstools.com/home/dt1/page_12997/ford_spark_plug_blow_out_problems_how_to_repair.html
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on Jun 02, 2010
  • HP Master
  • 6,993 Answers
okay, get a plug spanner, fix it into the button part of the plug that is still in the engine, and loosen the remaining part of the plug.
The plug will definitely come out once you use a plug spanner to loosen it.
Take care.
Posted on May 28, 2010
  • hpsaffold May 29, 2010
    this is a spark plug that is b roken in ther engine the tail end of the plug. this is a fF150 ford truck 2004
My ford F150 truck
auto transmission -check the reverse servo/ solenoid operation
manual transmission--check for loose selector fork for reverse , broken selector fork, stripped reverse gear, reverse gear key failure
Sep 15, 2016 | 2004 Ford F150
I washed engine at car wash ,now motor will not rev and runs bad
Im going through it now i found one of the coils had moister in it gentle compressed air dried it out it causes a short from plug coil to the block not hard to take out the front 4 coils im trying the back today use compressed air on the holes where the spark plugs are but dont touch the plugs as they can strip the treads on the head ( type blown spark plugs Ford on internet) good luck
Feb 23, 2013 | 2004 Ford F150
2004 F150 spark plug is stuck or broken. Is there a way to get it out without removing the heads??
I have an F150 that the plugs were replaced and out of the eight 5 of them broke off, Ford has a tool to do this with contact them or catch a dealer mechanic on the side see if ya can by the tools from a local parts store and get tips from the mechanic how to proceed.
Mar 22, 2012 | 2004 Ford F150
I hear a loud grinding noise when turning to the left. It is coming from the right front tire and I do not think it is the ball joints. We have tried a couple of basic tests on them.
Check the inside of the tire for signs of rubbing against something. Strangely worn tread, cuts, etc. would be signs of such.
Jul 21, 2011 | 2004 Ford F150
How to change spark plugs on 2004 ford f150
What's that about?
Remove the Coils,then the Plugs!!!!
Oct 11, 2010 | 2004 Ford F150
Broken tilt steering lever
BROKEN PART BEST FIX BY REPLACING BUT IF YOU HAVE THE BROKEN PIECE YOU CAN ALWYS TRY J B WELD SHOLU BE ABLE TO GET AT YOUR LOCAL AUTO PARTS STORE WILL HAVE TO DO SOME SANDIND DOWN FOR LOOKS
Apr 12, 2010 | 2004 Ford F150
2002 ford f150 4.2l wiring diagram
The COIL PACK TOWERS are numbered : coil----3---4 pack---2---6 plug----1---5 ----------------------------------------------------------------- The engine cylinders / spark plugs are numbered : passenger side , front to rear , 1 , 2 , 3 -----drivers side , front to rear , 4 , 5 , 6 ------------------------------------------------------------------- The spark plug firing order is ( 1 -4 - 2 - 5 - 3 - 6 )
Apr 07, 2010 | 2004 Ford F150
My 2004 Ford f150, when checked on a computer, says missfire in cylinder 1. We changed the coil, plug, and fuel injector, what can the problem be.
Switch the plug wire with one of the others and if your missfire moves to a new cylinder its a bad wire.
Feb 22, 2010 | 2004 Ford F150
Does the transmission on 2004 f150 have to be
no it does not but it is a good idea it gets all the old fluid out
Aug 20, 2009 | 2004 Ford F150
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
