Question about Electrolux EOB6632 Electric Single Oven
After 30mins the oven goes off, what is the problem
  • 327 Answers
Hello,when you opened the top you will find a small insulated plastic tube with two thermostats in side and maybe one of them was burned out,this assembly must be replaced with a new one ,they are all push on connections and are easy to replace turn the cooker switch off for oblivious safety
Thanks
Posted on May 28, 2010
Maytag cwe4800acb oven shuts off and display goes blank during heating
Display on maytag oven 8114p471-60 went blank - Fixya
www.fixya.com/.../t16018814-display_maytag_oven_8114p471_60_we...
Jan 20, 2013 - Stove top electric ignition still works fine, so there is power going to the .... maytag cwe4800acb oven shuts off and display goes blank during .
Oct 10, 2015 | Maytag CWE4800ACB 2.6 cu. ft. 24" Single...
I have a westing house 509 fan force oven the fan turns off when i turn oven off but the element still goes and goes and goes why
This sound like a switch problem, when you say turned off is the element glowing because the oven light is not working, or it has to be switched off at the mains switch to stop heating, could you clarify.
Nov 03, 2014 | Ovens
Over heating fan oven
it sounds like you tod is faulty its the little stat at the back on the right hand side two wires going to it ok make sure to swicth oven off
Oct 14, 2012 | DeLonghi Ovens
What is rhe best temperature for cooking bread in the Neff 1451 oven?
On circotherm at around 210 in a preheated oven for first ten minute, then drop to 190 until finished. For a 2-2.5lb loaf that would be 10mins followed by 20-30mins depending how dark you want it. On the neff ovens down the left side the shelfs are numbered 4 at the top down to 1 at the bottom... you should use the shelf set on 1 or 3 (**NEVER IN POSITION 2**). Good Luck. Hope this helps.ps you can prove the bread in the oven by setting the selector to 'fan' but with no temp, the heat from the lamp will create enough heat (obviously the bulb/lamp need to be working!!)
Sep 14, 2011 | Neff B1451 Single circotherm plus Electric...
My hotpoint oven heating for 30mins tonight when my husband noticed small fire/sparks inside. immed cut off power. when it cooled we inspected inside , two lenghts of what may have been element covered in...
What has happened is the element broke and it needs to be replaced. 99 and 1/2% percent of the time no other part went out and it just needs element. Go to the link i included and see where to find model# and reply back with it i'll give ya the part# be sure to tell me if it's bake(lower) or broil (upper) element.
http://www.geappliances.com/finder/ranges.htm
Gene
Jul 31, 2011 | Hotpoint Ovens
WHERE DOES WHITE WIRE ON WALL OVEN GO FOR HOOK UP - WE HAVE RED, BLACK, WHITE & COPPER
white wire goes in the middle copper goes to ground or chassis
Oct 04, 2010 | Whirlpool Ovens
Oven burns things, very hot on bottom
The temp indicator light goes on and off according to the temp selected.
The sensor referred to is part and parcel of the the thermostat, or temp selector
the fact the light goes on and off, shows that the thermostatt is working, but neccesserily at the correct temp.I maintain that the thermostat that controls the temp is faulty, and needs to be replaced.
Dec 21, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven timer goes off randomly
I would suggest that a new timer is needed.
Dec 07, 2008 | Jenn-Air Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
F7 on the display with constant beeping
F7 for GE is either a stuck button on keypad or bad EOC. Try shutting breaker off 20-30mins and see if it resets itself.
Jul 12, 2008 | GE JKP15 Electric Single Oven
Electrolux EOB6632 Electric Single Oven Logo
339 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
