Question about SanDisk Sansa e250 MP3 Player
4 Gb Sansa Formatted to 16MB!
My Sansa was accidently formatted to 16 Mb and cant do anything with it! Help. on my computer it shows up as 16 mb instead of 4 Gb's.How can I format it to et my 4 GB back? I dont have the set up disk that came with the sansa anymore!
Buy a new 1
Posted on Apr 08, 2008
SOURCE:
Windows unable format
For sansa e270 : lock the sansa by sliding the hold button. Hold record and power button together, it will show black screen and asking entering MSD mode- connect to computer, it will open in 16 mb format- open it and add a folder named "sansa.fmt" -disconnet it from computer now. it will formatted. u will lose all the data saved in it. bt the player will work as usual. it may be possible that u will not be able to view pics or vdeos.
Nov 23, 2013 | SanDisk Sansa Audio Players & Recorders
Flash drive file system unknown and unformatable
Sounds like the partition table is screwed up. I've tried simulating it as best I could. I created a 25 MB drive in this video and edited the partition table to show only 2 KB. Formatting only allows me to format the 2KB in your case it would be 0KB and formatting won't do anything. Try the steps in the video.
Jan 31, 2013 | SanDisk Electronics - Others
I bought this usb it was either a 16 or 8gb and when i plugged it in i set up the password and everything but when i insert it again it said there was only 7.95mb on it and ive never saed anything
> it was 8 GB
> there was only 7.9 MB
Do you really mean 'MB', not 'GB' ?
Some USB drives have an "emulation" of a CD-ROM programmed into it; the emulated CD-ROM contains a few MB of "setup" files, e.g., file-encryption software, or one-click-backup software.
Aug 26, 2011 | Computers & Internet
DFI NB78-BC, chipset i845PE does not work with TNT2 Vanta VL 16MB
I hate to be the bearer of bad news but the DFI NB78-BC does not support the TNT2 Vanta VL 16mb. so what you need to do is take your computer into a computer store have them look at it and they can get you the correct video card that is compatible for your computer!
Apr 05, 2009 | Nvidia Riva TNT2 16 MB Graphic Card
Transcend USB decreasing memory
It seems that some space in your flash drive has been corrupted..So u can't get back full 2 GB after formatting..
Jan 28, 2009 | Computers & Internet
XD memory card confusion
The xD-Picture Card (xD stands for "extreme digital.") is a flash memory card format developed and introduced to the market in July 2002 by Olympus and Fujifilm, and manufactured by the Toshiba Corporation. xD cards are in Olympus and Fujifilm digital cameras, and are available in a range of sizes, from 16 MB to 2 GB currently. A higher-performance xD card known as Type M came out in 2005, and uses Multi Level Cell (MLC) architecture.
An xD card is 20mm x 25mm x 1.78mm and weighs about 2.8 g, making it significantly smaller than the nearly matchbook-sized CF card and about half the size of the SD/MMC card. As far as size goes, it is much closer to miniSD or RS-MMC. The manufacturer listed write speeds for xD-Picture Cards are: for the 16 MB and 32 MB card, 1.3 MB/s and for the 64MB and higher cards, 3 MB/s. Both offer a minimum read speed of 5 MB/s. The xD Type M cards have a faster standard rate of 4.0MB/s for reading and 2.5MB/s for writing.
Anything up to 2gb will work with your camera, either the type M or the type M+ will be fine.
Dec 14, 2008 | Olympus Camedia D-540 Zoom Digital Camera
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
My sansa e260 didnt format right
format it using a program from C-NET
Jan 08, 2008 | SanDisk Sansa e260 MP3 Player
Not enough space to listen
If it''s any consolation, the same thing happened to me after I loaded about 1.6 GB (~250 MB left) of music on my Sansa m250. I tried to delete the required 8MB, but the directory structure got destroyed to the point where my computer wouldn''t recognize the device. I called their technical support and they''re having me send it back to them for a replacement! It''s not you, but the player! I don''t know if there''s anything that can be done from a consumer standpoint.
Jul 09, 2007 | SanDisk Sansa m250 MP3 Player
Help..!!!
sandisk have a upgrade to fix connection problem download, install it ,plug it and upgrade it via internet. works for me.
Mar 14, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
244 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
