Question about GE HSM25GFTSA Side by Side Refrigerator
Defrost controls location of defrost controls
  • 166 Answers
The defrost heater and termination thermostat are located on the freezer side at the evaporator coils behind the back panel. the control board is located at the rear of the refrigerator behind a metal panel.
Posted on May 28, 2010
Where is the defrost mechanism located in a kenmore 2218877REL refrigerator
Your model # is not coming up for me, but defrost systems consist of 3 components. Defrost Board or timer depending on model, defrost heater, and defrost thermostat. Heater and thermostat are located around evaporator and Board can be located around controls or on back if unit behind a removable panel. Some can be located around compressor
Oct 08, 2017 | Kenmore Refrigerators
DEFROST TIME CLOCK GE GSH25J, WHERE IS IT LOCATED?
Hello:
Your model does not have defrost timer, instead the defrost is controlled by Main control board located on the back of the fridge..
Part # WR55X10942
PS.. Most common defrost problem on this model is not the board. Its either defrost heater or defrost thermostat..
Jul 15, 2017 | GE Refrigerators
Model gss25jetabb. Where can I find the defrost timer?
The defrost timer is built into the control board and is likely not the problem with a defrost problem. Item location 801 in this photo is the control board=> HERE The most likely problem on your model is the=> Defrost Thermostat WR50X10068 and the=> WR51X10059 Defrost Heater location 240 and 230 in the photo=> HERE Appliance 911
Jan 03, 2016 | GE Refrigerators
Location of defrost timer on frigidaire model lfus2613f3
Hello Friend, thank you for allowing me to assist you!
It appears that the defrost timer of your Frigidaire refrigerator (LFUS2613F3) uses the main control board to energize defrost. The defrost timer is located at the front of the control console in the fresh food compartment (display that controls all functions). I do hope this information proves to be helpful! - Z
Jun 04, 2014 | Frigidaire FRS26KR4A Side by Side...
Where is defrost timer location on fridgedaire mod # ED25DQXVN00
Your mechanical defrost clock timer is located in the control panel where the rotary knobs are for the ED25 model given which is a Whirlpool SxS, For the Frigidaire Mod FRS, your defrost control will most likely be located in the long housing running down the center wall (front to back) of the fridge near the outlet vent, this is an electronic adaptive defrost control. Pleazer Appliance...
Apr 18, 2014 | Frigidaire FRS26KR4A Side by Side...
Ge refrigerator top freezer is frosting over
Refrigerators that self defrost have three main components that cause defrost to take place. On your model GTH18ECC2RBB there is a WR55X10397 Defrost Control Board
This part is most likely the problem and is found inside the fresh food compartment and inside the control panel. The location is 257 in this photo HERE Sometimes the defrost control board will show burn marks but not always. The other two parts that may be defective are the WR51X10038 Defrost Heater
The WR51X10038 Defrost Heater is location 618 in photo HERE
and the=> WR50X10071 Defrost Thermostat
The defrost thermostat is location 630 in photo HERE a tutorial of how to test the defrost heater and defrost thermostat can be found on the parts pages listed above. I will try to put the defrost heater test below. I think the defrost control board is most likely the problem here so look it over first. Manually defrost the evaporator with a hair drier so you can remove the defrost heater and test for continuity. I am here should you have questions Thanks Sea Breeze
Apr 03, 2013 | GE Refrigerators
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Feb 16, 2012 | GE Refrigerators
Location of defrost timmer
The defrost timer on your model is inside the fresh food compartment and behind the controls. Just above the top shelf. Click Here=> FRS23W3A Control Panel
Location 23 in that photo is the timer part Number=> 215846602 Defrost Timer
Some model's have the=> 240375803 Adaptive Defrost Control
Either way should you have questions I will be here to help you. Please rate this solution, Thanks, Sea Breeze
Jun 20, 2011 | Frigidaire FRS23W3A Side by Side...
Im looking for the automatic defrost control location for a Frigidaire. Model # FRS6HR5HSB6, Serial # 4A80118247. My refrigerator compressor has stopped working for about 14 hours. I think it is stuck in...
If your compressor is the only motor not working, meaning you also hear no other noises at all, advancing the defrost control out of defrost MAY solve your problem. However, if you do hear other motors running, then your refrigerator is not stuck in defrost, and advancing the defrost control will not help. But to answer your question, if you have a mechanical defrost control, and not an adaptive or electronic defrost control, it will be located behind the toe grill under the freezer door. If there is no control located there, then you likely have an electronic control, located inside the fresh food compartment, mounted along the top left side, contained within the housing. But if it is an electronic control, you will not be able to force it into refrigeration, as it is electronic.
Oct 26, 2010 | Refrigerators
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
GE HSM25GFTSA Side by Side Refrigerator Logo
207 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
