Question about LG enV VX9900 Cellular Phone
How do i download page plus wap settings to my vx phone
Some where my wap download got hang in my set and it occupied my space in hand set need to clear it
You can try these in case you downloaded corrupted or incompatible Java midlets or other media, which are causing problems with the phone
*2767*WAP# Wap Reset
Please contact your network provider in order to obtain you WAP settings.
They will kindly give you the necessary proceedings in order to activate your WAP Settings on your phone.
Feb 24, 2012 | Samsung SGH J150 Cell Phone
Tip
Bsnl 3g manual settings,tv settings,bsnl wap settings,bsnl portal settings,bsnl...
TO get settings directly to your phone visit this link http://218.248.72.246/msp/html/authenticate.jsp
this settings for connecting internet from mobile to pc,
setting name : bsnlnet
access point name : bsnlnet
homepage: www.bsnl.co.in
authentication : normal
user name : leave blank
password : leave blank
WAP SETTINGS
setting name : bsnlwap
access point name : bsnlwap
port : 9201 for wap 1.0 device,8080 for wap 2.0 device
home page : http://wap1.cellone.in
PORTAL SETTINGS
setting name : bsnlportal
access point name : bsnlportal
port : 8080 for wap 2.x device & 9201 for wap 1.x device
proxy ip : 10.220.67.131
home page : http://wap.cellone.in
MMS SETTINGS
setting name : bsnlmms
access point name : bsnlmms
port : 8080 for wap 2.x device &9201 for wap 1.xdevice
proxy ip : 10.210.10.11
uere name : leave blank
home page : http://bsnlmms.in
BSNL LIVE PORTAL SETTINGS
settings name : bsnllive
access point name : bsnllive
port : 9201 for wap 1.0 device & 8080 for wap 2.0 device
username : leave blank
home page: http://bsnllive
BSNL MOBILE TV STREAMING
Setting Name : bsnlstream
Access Point Name : bsnlstream
Homepage : None
Authentication : Normal
User Name : <leave blank>
Password : <leave blank>
CP MOBILE STREAMING
Setting Name : bsnlmobiltv
Access Point Name : bsnlmobiltv
Homepage : None
(Open Real Player: Options-> Settings-> Connection-> Network->default)
APN (Should be "bsnlstream")
Minimum Port: 5001, Max Port: 32768
2. APN "bsnlwap" (Not Required for Sony Ericsson Sets)
- Set proxy IP: 10.147.4.131
- Port: 8080
And check all wap sites with this APN.
With this APN, On the handset download the MobiTV Application (3PP Application).
to get settings directly to your phone http://218.248.72.246/msp/html/authenticate.jsp
Send SMS “MY3GTV” to 55447.
And you will receive the WAP Push from Apalya TV. Click on the link and download the application.
Once Application is downloaded on the handset, you can watch live TV from the Applications on the
handset using httpnorth3g.bsnlmobile.in.
For TV
1. After Receiving WAP push, Click on the link and download the application.
2. For Sony Ericsson sets, click on “Get Activation Key”Link & Press “Submit”. After receiving the
activation key, put the activation key and press “Purchase”.
3. Pl. check the compatibility list of handsets, whether the set is supported by the Apalaya server.
on Mar 19, 2010 | Cell Phones
Can you send reliance gprs setting to my mobile nokia 5130 please my no is 9022808844
Reliance GSM GPRS Settings
__________________________________________
Reliance GSM WAP Setting
( Required to run RWorld )
( Postpaid and Prepaid )
APN: rcomwap
Login Request Required : off
Authentication : PAP
Data Compression : off
Header Compression : off
Settings Name: Mobile World
Home Page / WAP Page: http://wap.rworld.co.in
Proxy: Yes
Proxy Server Address : 010.239.221.005
Port : 8080
Full Address in case of Windows Phone : 010.239.221.005:8080
User Name = leave it blank
Pass word = leave it blank
Reliance GSM MMS Setting
( Required to to Send and Receive MMS)
APN: rcommms
Settings Name: Reliance MMS
Proxy: Yes
Port : 8080
MMS Server Settings
Server URL: http://10.239.221.47/mms/
Ip Address: 10.239.221.5
Apn: rcommms
IDRISH 911
Nov 11, 2010 | Nokia 6300 Cellular Phone
Browser is not set up. how do i set it up?
WAP settings are carrier specific. You will need to contact your carrier (is this Page Plus by chance) for the exact settings required.
Jun 22, 2010 | Motorola Mobility SLVR L7 Cellular Phone
NEED TO CONFIGURE THE INTERNET SETTING,
To get your Glo 3G internet settings, you will send SMS activate to 444 using a 3G mobile phone. Save the internet settings in your mobile phone. To get Glo WAP settings, SMS your phone name and model to 927. e.g, to activate Nokia 2630, SMS Nokia 2630 to 927. Save the internet settings in your mobile phone.
Glo manual 3G/3.5G internet settings
Service name: Glo 3G
IP Address: 10.100.98.22
Port: 3130
Username: wap
Password: wap
Access point name (APN): glo3gvideo
Authentication: Normal
Home page: http://cms.gloworld.com
Jan 27, 2010 | Samsung Gravity SGH-T459 Cell Phone
I9 wap/gprs & mms settings for O2
First you have to make 2 data accounts,
1 for wap,
1 for mms.
Press service,
Data account,
GPRS, ok,
Pick any one of the settings because you are going to change it,
Press edit.
account name edit to O2 WAP GPRS,
APN to payandgo.o2.co.uk,
user name to payandgo,
password is password,
authentication type normal,
after each one if done is the option press it. this is the setting for wap internet.
You have to do the same again to make a new data account for the mms. the settings for this is
account name O2MMS,
APN payandgo.o2.co.uk,
user name payandgo all others same as before.
Now you have 2 new data accounts you need to set up wap.
press service, wap, settings, edit profile, sim 1 or 2 which ever you are using,
select the O2 WAP GPRS account that was made earlier,
press ok. press edit profile,
rename profile is ok it is O2 WAP GPRS,
edit home page to http//wap.o2.co.uk,
set data account to O2 WAP GPRS,
connection type wap, IP address 193,113,200,195
user name payandgo,
press back and activate profile.
you should be able to get on to o2 homepage now.
To get mms
press text, mms, mms settings, server profile, sim which ever you are using 1 or 2 ,
select the O2 MMS made earlier, edit profile, rename profile is 0k should be O2 MMS, home page is http//mmsc.mms.o2.co.uk:8002,
data account is the O2 MMS you made before,
MMS IP address 193,113,200,195
user name payandgo,
select back when all settings are entered and select activate profile. this should be it.
This works OK for me.
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
To activate gprs in htc p3350
Thank you for choosing Fixya.com
Please follow the instruction below very carefully and make sure that you have load of your sim enjoy.
For Globe Subscribers:
For a complete listing of compatible MMS & GPRS phone handsets — send NOKIA, ERICSSON or SAMSUNG (your handset model) to 2365.
To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1)
Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
Enter 1234 when asked for PIN to save settings.
Send an MMS message for only Php 5.00 to activate the service.
Note: For prepaid subscribers, please make sure you have credits first before trying to access GPRS/MMS. You won’t be able to use the service if you have zero balance.
For Smart Subscribers:
OTA (over-the air) configuration
a) To activate GPRS *and* MMS
- SET MMS send to 211
- wait for the configuration to be downloaded to your phone (up to 24 hours)
- once downloaded, you will have SmartMMS data account, and SmartMMS WAP profile, and your MMS is configured already to use SmartMMS WAP profile
- you will also receive a confirmation message that your GPRS and MMS have been activated
b) To configure internet access (full access)
- SET INTERNET (handset model) send to 211
- wait for the configuration to be download to your phone, in minutes
- once downloaded, you will have SmartPC data account, and SmartPC WAP Profile
- edit this account to include DNS settings. DNS IP addresses are -202.057.096.003, 202. 057.096.004. you only need one.
c) To configure WAP via GPRS
- SET GPRS T68 send to 211
- once downloaded, you will have SmartGPRS data account, and SmartGPRS WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
d) To configure WAP via CSD (Optional - kasi MAY BAYAD ITO, per minute)
- SET WAP T68 send to 211
- once downloaded, you will have SmartWAP data account, and SmartWAP WAP Profile. SET THIS AS YOUR DEFAULT PROFILE
I suggest you clear all your existing data accounts and wap profile beforeyou do this. If you follow the instructions in this order, SmartPC will have a CID=2. Your dial-up number willbe *99***2#
or to simplify it:
Setting up of MMS and GPRS handsets:
To download SMART MMS phone settings, key in SET MMS and send to 211.
To download SMART GPRS phone settings, key in SET GPRS and send to 211.
Activating SMART MMS and GPRS:
To activate SMART GPRS, key in GPRS ON and send to 333.
To activate SMART MMS, key in MMS ON and send to 333
Upon receiving the configuration settings, select "Save All" to save the settings in the phone.
Activation of MMS and GPRS will require a confirmation message from SMART. A message will be sent to the sub once the feature has been activated.
For SUN USERS:
Sun MMS
On the home screen, press the Programs soft key, press More to move to the next page.
Press Accessories then select MMS Setup by pressing the Action button.
Provide the following data on the required field, press Ok when done.
q First field: MMS connection
q IP: 202.138.159.78
q Port: 9201
q MMSC Address:
q Message Expiry: 1 day
q MMS Download: Auto
Press Settings, select Data Connection.
Press the Menu soft key then select Edit Connection by pressing the Action button
Select GPRS Connection. Press Menu then select Add by pressing the Action button
Provide the following data on the required field:
q Description: Sun MMS connection
q Connects to: MMS Connection
q Access point: mms
When finished, press Done four times.
Sun GPRS
Press the Menu soft key then select Edit Connection by pressing the Action button.
Select GPRS Connection. Press Menu then select Add by pressing the Action button.
q Description: Sun GPRS
q Connects to: The Internet
q Access point: minternet
Press Done three times. On the Data connection, select Sun GPRS under Internet connection.
When finished, press Done.
Sun WAP GPRS
q Description: Sun WAP GPRS
q Access point: mms
Press Done three times. On the Data connection, select Sun WAP GPRS under WAP connection.
Sun WAP Proxy
Crate a proxy connection
Description: Sun WAP Proxy
Connects from: The internet
Connects to: WAP network
Proxy (name/Port): 193.113.200.195
Type: WAP
To Activate GPRS:
Create a text message, type "ACTIVATE" then send to 2300
please don't forget to rate our answers properly.
Feb 23, 2009 | HTC P3300 Smartphone
Unable to download mms on rocada xphone
get you network setting from your provider if they are wap or http get the proxy address and the server name and create a new profile under gsm and gprs
Jan 21, 2009 | Cell Phones
Wap settings for motorizr z3
Regular rogers wap
(not using phone as modem)
uses navigate plans
http://www.shoprogers.com/store/wir...ng/overview.asp
apn: goam.com
username: wapuser1
password: wap
IP 208.200.067.150.
or
172.025.000.107
Rogers Media settings
(for MMS/PICmessaging)
http://www.shoprogers.com/store/wir...remessaging.asp
apn: media.com
username: media
password: mda01
mms.gprs.rogers.com
ip 172.025.00.107
Rogers internet.com settings
(to use phone as modem. Or is needed for HTML phones, or wap 2.0 phones at this current time.
requires access to a Data access plan
apn: internet.com
username: wapuser1
password: wap
ip: same as goam, 208.200.067.150
Dec 06, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
LG enV VX9900 Cellular Phone Logo
225 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
