Question about Whirlpool Duet GHW9150P Front Load Washer
I get code DL and F02 when I press to start the washer. There is water in the drum. Attempted to change from wash cycle to the drain and spin, but it does not start.
  • 5,911 Answers
First, attempt to reset the Central Control Unit (CCU) on the washer by unplugging the unit for AT LEAST 30 miunutes. Sometimes these error codes are erroneoous and can be corrected by resetting the washer program. If this fails to correct your problems, then you have legitimate errors that need tobe corrected before the washer will operate again.
"Fdl" is a door latch error code. This is an indication of either a defective door latch, defective Central Control Unit (CCU), or an interconnecting cable problem between the two. The following link explains how to troubleshoot the problem:
http://www.fixya.com/support/r4490349-fdl_error_code
"F02" is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system, or a failed drain pump. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If the door remains locked and will not open, the following link explains how you can use the manual release to get the door to open:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
You may want to try using a wet/dry shop vac to pull a vacuum on the drain hose to try to pull as much of the water (if any) ot of the wash tub BEFORE opening the door. The water can become sour and may have a strong odor.
NOTE: For an explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
Posted on May 28, 2010
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
I've gotten the error code DL and then F, I tried sanding, unplugging but it still shows me the error. How can I fix it?
Hope this helps.
Shane
Mar 15, 2011 | Kenmore Elite 45986 Front Load Washer
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Dec 20, 2010 | Kenmore Elite 45986 Front Load Washer
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model GHW9150PW0 shows code F02. The washer did nor complete the spin cycle and water was left in the tub. How do I get access to the pump. How do I remove the panels. Thank you
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
Potential Causes
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Aug 04, 2017 | Bosch Axxis+ WFR 2460 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De
