Question about SkyGolf SkyCaddie SGX GPS Receiver
Registration i have just bought a skycaddie sg5. i need to register it before use. cannot find website myskycaddie.com?
Where do I find Caddiesync>
Posted on Dec 24, 2010
Register my sky caddie
To register your sky-caddie
connect to a WI-Fi network, then highlight the "Wireless" icon on the Main Menu and select it by pressing the Right Key beneath "OK".
Upon syncing, u will see a code on your device, write it down
Open a web browser on your computer and go to
http://www.skygolf.com/register
Enter the Registration Code in the code field on your computer and click Start Activation.
Follow the on-screen instructions to complete the registration process and select a membership plan.
When you have completed the process on your computer, simply select "Sync" using the Right Key on the Skycaddie. The "Sync" option appears on the same device screen as your Registration Code.
May 06, 2015 | GPS
New battery and still not holding charge
Not sure what kind of battery you are using in your GPS. If you can put in AA or AAA size batteries, try to use NiMH rechargeable batteries the can be bought with capacities till 2500 mA/h. (sometimes suggested 2700 on the battery) but still 2500 mA/h is very much. Do charge the batteries with a charger that is capable to charge correct. When putting a NiMH battery on an old charger for NiCd batteries, the battery never get the full capacity.
If the Battery is inside and you must go to a repair shop for replacement, please ask if they can check if the GPS is not draining to much power, because of any malfunction.
Oct 28, 2013 | SkyGolf GPS
My sky caddie sg5 won't charge thru the usb or power cord...any ideas???
Hello there,
Since you have tried charging the device using the usb and the power cord. It is quite clear to know that the problem is from the device connection port. It is bad and need to be replaced.
But you need to Try to test the battery in other devices then try to charge it there to see if it will hold a charge. If the battery holds a charge there, then it means the battery is okay and if it does not charge. Then it means the problem is from the battery. It need to be replaced if so.
Then test the charger/ power cord on another device if it is not bad, then you test the usb cable also. After running these test. You will be clear to know if it is the connection port. Then replace the connection port once confirmed to be the problem. Hope this helped. Goodluck Elect_Comp
Sep 02, 2011 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
How do I download skycaddie program back on to the computer. I already have a subscription for the year
THIS HELP YOU
http://wareseeker.com/free-sky-caddie/
www.skygolf.com/ -
Sky caddie Free Download,Sky caddie Software Collection Download. ... English and Dutch versions avilable.sky caddie. foxfire mail, Download now ...
www.brothersoft.com/downloads/sky-caddie.html -
Mar 01, 2010 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Having problem registering and activating skycaddie sg5 golf range finder
I have seen Few Issue's with this. You could only try Few Tricks, if that would work.Turn OFF Anti-Virus and Firewall as it could stop you Registering on that Site. Reinstall the Software and then try to Register.
If unable, try to Register on a Different Machine. If still problem remains the same, contact Technical Support - Skycaddie to register your Complaint. It could be a Server Down issue or Web Site Security issue which they need to check from there side.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 12, 2009 | Sport & Outdoor - Others
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
How do I install caddieSync?
cannot log on to skycaddiesync for my new skycaddie.
Jul 30, 2009 | SkyCaddie SG2.5 GPS Receiver
SkyGolf SkyCaddie SGX GPS Receiver Logo
1,092 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
