Question about Ryobi FactoryReconditioned 6 Amp SDS Rotary Hammer ZRSDS60K
I have Ryobi drill + hammer
Model no. EID 24700K
700 Watt varriabel speed.
Promlem now not working Slow speed .Allways working fast speed.which one part changce.can you give me any answer.Please.
3 Suggested Answers
SOURCE: Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Posted on Mar 20, 2009
rycgl
  • 1545 Answers
SOURCE: How to remove the carburator from the Ryobi SS30
It may just need a G & D kit installed. That is a gasket and diaghragm. Just take the 4 Torx screws out of the rear cover and remove it. You will then be looking at the choke plate assembly which has 2 long screws that go through the housing of the carb and screw into the rear crankcase cover/reed valve assembly. Pull the 2 fuel lines off (noting where they went) and you'll have it. Once you have the carb off, you can get the manufacturer and model # off of it and order a kit. The G&D kit will probably fix what ails it or you can go for a complete rebuild and get a rebuild kit. If the carb is a Zama or Walbro, they sell the kits on Ebay.If the carb has brittle diaghrams inside, replace them; if they are still soft and pliable, then you may only need to clean the carb real well and adjust the H and L mixture screws. They will be plainly marked, but are difficult to remove. Post back for more help!
Posted on Oct 19, 2010
I have a 18v Hitachi 3ah battery which works fine in my saw, lantern & torch but will not work in drills
Batterys are not necessarily universal even withing voltage ratings by make and model. A bone of contention for many users for many years.
Rigid and Ryobi are two companies that have use standard batteries for their tool line. Consider this when making future tool purchasing decisions.
Thanks for your interest in FixYa.com
Feb 14, 2010 | Hitachi Dv18dl 1/2 18v Hammer...
Chuck removal on a ryobi
go to my site and under the tips section there is a detailed description on how to remove this chuck
Dec 10, 2009 | Ryobi Drills
Hi. i have ryobi a 3 speed hammer drill that won't run but attempts to start
it sounds like a damaged switch. It is best to have it checked and replaced if it is broken. It´s better to do before it starts running and wont come off :D
Oct 15, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Jammed 2 speed switch
sometimes you have to rotate or just try to move chuck a little to align gears then try to change
Sep 27, 2009 | Drills
I have a ryobi d551H hammer drill and I can't get it to work in only hammer mode....what am I doing wrong...I don't have an instruction manual
The spindle still spins, even in hammer mode. This model will jump out of hammer mode, sometimes you will have to duct tape it in position hammer.
Aug 29, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Drill quit working
what you are missing is a dewalt hammer drill.
Apr 25, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
I HAVE A 1992 RYOBI HAMMER DRILL MODEL ED-382P WHO CAN REPAIR IT IN DALLAS, TEXAS
As per the Ryobi web Site, there is unfortunatly no repair centers in Dallas. Go to if you go to the Ryobi website look under "support". They list a bunch of centers for Texas.
Apr 23, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
RYOBI hammer drill model D551H dosn't start.
The problem could be somthing as simple as the cord, or the switch, or it could be that the motor has failed. There is no way to know unless you test the internals of the unit. If you are not familiar with that procedure I would take the unit to a service facility.
Apr 07, 2009 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
Ryobi FactoryReconditioned  6 Amp SDS Rotary Hammer ZRSDS60K Logo
69 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
