Question about Sharp 25VT-J100 TV
Cable plug in back forcefully removed.
The cable attach plug in the back was forcefully removed from the Sharp 25VT-K100 TV. I can access the separate circuit board but don't know where wires would go. When I get the new plug, how many wires will there be? Where will they go on the board?
  • 4,234 Answers
The cable conmnector (F-connector) attaches directly to the tuner board. There is only the center connection and the ground connection. This is a simple repair for a shop but requires a bit of practice (you can't melt the inner insulator). The part costs around $2. Check with a local shop for their repair charge.
Dan
Posted on Apr 08, 2008
Red vertical line on the screen due to external shock
This is most likely caused by the cable on the T-CON board being bent out of place by the shock.
If you know how to work on electronics or have a friend with knowledge/skill you can fix it.
DO THIS ONLY IF YOU KNOW HOW TO WORK WITH ELECTRONIC EQUIPMENT.
REMOVE THE PLUG FROM THE WALL. REMOVE INPUT signal cable from set.
REMOVE THE POWER CABLE FROM THE SET.
>Lay the set down on a flat cloth covered surface.
>Remove the back cover.
>Remove the shield covering T-CON board. This small board is located in the center near the top.
>Move the cable(s) connected to the T-CON around.
> Set the tv upright and make sure it is stable.
DO NOT TOUCH ANYTHING ON THE BACK
ATTACH INPUT SIGNAL cable to set.
ATTACH THE POWER CORD TO THE SET.
PLUG THE POWER CORD INTO THE WALL.
>Use the remote to turn the set on. If the vertical lines are gone, THEN TURN the set OFF.
REMOVE THE POWER CORD FROM THE SET. Remove signal cable.
> Lay tv back down on table.
CAREFULLY REPLACE THE SHIELD over the T-CON.
Replace the back cover etc.
Now you can reconnect the input cable and power cord.
SOMETIMES THE IMAGES can get worst and you have to repeat moving the cable around. In the worst case you can dis-connect and re-connect the flat cable WITH THE SET UNPLUGGED.
I believe the T-CON may sometimes be called LVDS and look similar to;
Feb 15, 2011 | Sharp Aquos LC52XD1E 52 in. HDTV-Ready LCD...
Call button won't work
The reason the call button stopped working is as a result of a problem affecting the flex of the phone.
The flex is the cable that assist the information from the panel to reach the screen.
so as you are pressing the dial button, its message is not being transferred to the panel of the phone.
all you have to do is to change the flex of the phone.
to change the flex of the phone,
  1. get the appropriate screwdriver(Phillips screwdriver, plastic tool such as a guitar plectrum or credit card),
  2. Remove your back cover, battery, sim and memory card.
  3. Remove the four screws you can see.
  4. Peel back the sticker, You may need something with a thin, sharp point to peel the sticker back with.
  5. Two rubber stoppers need to be levered out to reveal two more screws that must be removed.
  6. Run your plastic tool along the join of the battery compartment to separate the phone into two halves, as shown below.
  7. Next you need to disconnect the ribbon, This attaches like a plug and socket. Simply lift the connector up, away from the circuit board to unplug it.
  8. Remove the screw, You can now lift the green circuit board away from the phone. A little force is required.
  9. You should now have the circuit board removed, like below. Note that a ribbon, will have disconnected when you removed the circuit board. Again, this attaches like a plug and socket.
  10. Remove the identification sticker.
  11. Remove the volume button which will be loose. The buttons underneath will be lightly stuck to the side of the phone and need to be peeled away.
  12. Lever off the grey part.
  13. Remove the four screws you have access to (one is under the ribbon cable).
  14. You should now be able to separate the phone into two parts. Two rubber stoppers need to be levered out to reveal two screws.
  15. Remove these plus the two others screws you see.
  16. Run your credit card around the join of the housing to release it. Once you have the two parts separated far apart, then pull it backward.
  17. then you carefully disconnect the flex cable that is behind the screen.
  18. replace it with a new one.
take care
Jun 19, 2010 | Samsung J700 Cellular Phone
Hi i can connect my ps3 to my tv 25vt-k100 what
You sure can, all you need is the RCA cables. it may not work very good but it shouldn't stop you from connecting it to the Sharp 25VT.
Just make sure you still have the Yellow/Red and White cable that came with the PS3, if you lost it or missed placed it, I am sure you can find one cheap on-line or any local electronic/video game store.
I couldn't find out if you have the RCA connections on the TV but from the pictures I found it looks like you have them in the front and it may only be the Yellow and white ones, but that should still work
Apr 14, 2010 | Sharp 25VT-K100 Combo
Any way to access on-screen menu on Sharp 13F-M50 without remote
try ebay with the model number; I had the same thing with a sharp set I own---only way to access the menu and do things is with an original remote--if this was helpful please vote for me.
Aug 08, 2009 | Sharp 13VT-K100 13 in. Combo
Toshiba 32'" tv wont give sharp picture
no rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
Jan 26, 2009 | Toshiba 36A50 36" TV
No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Dec 15, 2008 | Sharp LC52SB55U LCD TV
25VT-K100 Tamperproof
try unplougging the tv and then put it back in again
Jun 02, 2008 | Sharp 25VT-K100 Combo
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
