Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a craftsmen mower that is about ten years old it has a briggs 17.5 hp motor. was mowing yesterday in some tall grass and it made a noise like I had hit something and it died. pushed the mower out of the grass and checked undr the deck nothing blocking the blades.tried to restart and motor acted like it was locked up. turned mag counter clockwise and then it appeared to free it up. tried to start it and motors cranks but faster than before almost like no compression and it will not fire
  • qy700forever May 28, 2010
    Thanks. Is this a costly fix or will the engine have to be replaced
  • 10,319 Answers
You did in fact hit something if the engine cranks faster than it did before
The cam that drives the valves to open and close is broken is your case since no compression is available
Posted on May 28, 2010
    so is this a costly fix? or will I have to replace the engine.
I have a series 725 briggs and stratton engine in my 2013 craftsman lawner mower. It runs well when mowing except when I start to bag clippings. After 3 bags, it will not restart for about an hour.
are u bagging wet tall grass ? could be bogging down the motor and getting to hot ,this has happened to a self propelled walk behind craftsman 6hp
Aug 26, 2017 | Craftsman Garden
Replace stripped gear
This sounds to me like a simple governor issue, and to be more precise a tensions spring. Along with the the linkage rod from the governor arm to the carburetor should be a small spring as well, check it and make sure it hasn't come loose or even fallen completely off. This spring works to make the govorner transitions slower and smooth and eliminates bouncing back and forth of the gov. I hope this helps.
Oct 01, 2013 | Briggs & Stratton Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
LT1000 cranks but won't start
check to see if you lost spark if not spray starting fluid and see if it fires that will tell you if it's a fuel prblem
May 21, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My briggs and stratton twin cylinder engine runs good until I try to mow with it. The engine dies down and will cut off unless I disengage the mower.
If you are cutting to much grass this can happen or if the throttle control is not in fast speed (rabbit). If it is in slow speed (turtle) it will tend to die down in tall grass or wet grass. Good Luck...
Aug 16, 2011 | Garden
I tried to mow the grass even though it rained this am. our grass was really high and i saw a little smoke come out of the lawnmower. is that because the grass was still a little wet or the grass was...
Nope. If the grass is too high, knock it down to size with a weedeater first. These electric mowers cannot handle the tall, high stuff. If you do, you will surely burn it up.
Aug 14, 2011 | Black & Decker 18", 6.5a Electric Mower
I bought a Weedeater with a Briggs and Stratton engine less than 4 months ago. While mowing thick grass (all my grass is thick this year) it boggs down and gaggs out. Fuel starts spitting out the vent...
You need to check two things. First, what size (horsepower) engine does it have? and second, how sharp is the blade? If you mowing that hard continuously, you'll need a very sharp mower with a good amount of horsepower or you'll just kill the poor thing. I would recommend you have at least 6 HP if that grass is giving you that much trouble. Be sure your blade is sharp (sounds like it's not) or it will just bash the grass down instead of cutting it off. Have your blade professionally sharpened, or better yet, buy a new one. They only run around $15 USD for a standard 22 inch blade. I hope this helps. Best of luck to you.
Jun 29, 2011 | Briggs & Stratton Garden
17.5 briggs on craftsmen riding mower
i gess you busted the crack shaft push rod so the piston is not now moving up and down the bore
take off the cylinder head and turn the motor by hand till its at the top of the bore, then rock the flywheel to and frow if its turns a long way before the piston moves down the bore strip the engine down so you can repair it,,,if thats pos!
May 28, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Craftsmen LT 3000 will not crank
That Briggs engine is not a good engine it has a weak governor gear that is known to come apart for no reason what so ever it may have done so and some of the parts stopped the cam gear from turning. Good luck!
Aug 24, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
141 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
