Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
17.5 briggs on craftsmen riding mower
Was in tall grass mowing engine made a noise like it had hit something and died. pushed it out of grass tried to start wouldn't crank turned mag backwards and then it would crank very fast but not fire. where do I start to find problem
    President:
  • 2,702 Answers
I gess you busted the crack shaft push rod so the piston is not now moving up and down the bore
take off the cylinder head and turn the motor by hand till its at the top of the bore, then rock the flywheel to and frow if its turns a long way before the piston moves down the bore strip the engine down so you can repair it,,,if thats pos!
Posted on Jun 06, 2010
Tucomse moer 5.5 Won't speed up when cutting tall grass.
These push-mowers have a limited power, when you hit tall grass there is much more resistance on the blades. Even higher power riding mowers can stall on tall grass.
Aug 04, 2015 | Garden
Craftsman lt 1000
Sounds like you installed the blades backwards, so the blunt edge of the blades are hitting the tall grass. This would cause the engine to bog down and almost die.
When replacing blades, always note the direction of the cutting edge. If possible, take a digital photograph of the old blades so you can refer to the picture so you can be sure of the direction.
If you go to Sears.com and search your model number, you should be able to find an owners manual that tells you how to install the blades.
Sep 02, 2014 | Garden
Replace stripped gear
This sounds to me like a simple governor issue, and to be more precise a tensions spring. Along with the the linkage rod from the governor arm to the carburetor should be a small spring as well, check it and make sure it hasn't come loose or even fallen completely off. This spring works to make the govorner transitions slower and smooth and eliminates bouncing back and forth of the gov. I hope this helps.
Oct 01, 2013 | Briggs & Stratton Garden
Yardman 38" 7160 the deck belt is loose
Have you been mowing high grass, and how long has the belt been on? if you have mowed tall grass or belt is older than 2 years old it needs replaced, most don't realize how much a belt stretches from mowing tall grass. I hope this has been helpful.
Sep 27, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My briggs and stratton twin cylinder engine runs good until I try to mow with it. The engine dies down and will cut off unless I disengage the mower.
If you are cutting to much grass this can happen or if the throttle control is not in fast speed (rabbit). If it is in slow speed (turtle) it will tend to die down in tall grass or wet grass. Good Luck...
Aug 16, 2011 | Garden
Why does grass get hung up in the chute for a rear debagger?
Typically, wet grass or tall grass will get caught. Mow only when dry and make sure your blades are sharp. Mow with the engine at full speed [VERY IMPORTANT] adjust your ground speed by using the proper gear for your conditions. With the engine at full throttle, choose a lower gear when cutting higher grass. Make sure the air outlet of the rear bagger is unobstructed. It has to be able to breathe.
I trust you will find use of these techniques will lessen the clogging rate you are experiencing.
Thank you for your question @ FixYa.com
Jul 11, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
201 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
Daryl Gleaton
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
