Question about DeLonghi WIR2LP Ceramic Compact Heater
Once I try starting the heater pilot comes up but
Once I try starting the heater pilot comes up but as soon as 'i leace the button to keep it on it goes off
  • DeLonghi Master
  • 3,313 Answers
Clean pilot could be blocked not heating the thermocouple , or change thermocouple
Posted on May 29, 2010
When I try to start my mr. Heater I hold the pilot button down and the starter knob won't do anything? I can't get it to light the pilot, I've only had it a month.
Gas is turned on? Pilot button is in pilot position? Push and hold pilot button down, keep holding it down, push igniter many times, while keep holding down pilot button, keep holding until pilot lights. May take several minutes.
Feb 14, 2017 | Mr. Heater Heating & Cooling
Pilot goes off as soon as I release the button
You need to hold the button down for about 3 mins. If it goes out after that long the thermocouple is probably bad. Look at how long the wire is from the pilot light to the gas valve. They come in different lengths.
Jan 18, 2016 | World Marketing Kozy-World 3 Plaque...
I have a model HE424M 33Mj/h gas Pyrox Firestar gas heater. I have just cleaned it and now it does not start. The pilot light is ok as is the spark but as soon as I let go of the centre button tha whole...
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out.
Sep 22, 2010 | Heating & Cooling
My 3 year old "Smart Water" heater will not turn on. No hot water
It sounds like there is air in the line, so open the gas line just a little for a few short seconds to let some gas out, after that, keep the one red dial on pilot then turn the other to about medium. Light the pilot by depressing the red button, then once the pilot is lite, continue to hold the red button for about 1 minute, Once that is done slowly release the button and then turn the dial that is set to pilot to on position and give it about 1 hour to heat up
May 08, 2010 | General Electric GE SmartWater Household...
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
The pilot light on the swimming goes out as soon as I try to ignite it.
Are you holding the pilot button down when lighting the pilot light?
Hold it down longer once the pilot lights........ a minute may be necessary.
Sep 06, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Pilot low when release button, goes out after turn on
Try replacing the pilot generator which is in the pilot assembly. It is the piece with a silver cable coming out of it and that cable splits open into a red and white wire at the gas valve, That piece holds the valve open once it is hot enough and is likely not putting out enough voltage to do its job.
Jun 14, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Pilot
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi jim2869
I am assuming it is a Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Hope this helps. Regards Bryan
Apr 09, 2008 | Endless Summer 2009 Open Flame Patio...
DeLonghi WIR2LP Ceramic Compact Heater Logo
268 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
