Question about HP Officejet 5610 All-In-One InkJet Printer
It takes unduly long time to cancel a print-command on any printer, when we work on Windows. What is the surest way to kill a printing command.
  • 4 Answers
Open "Printers and Faxes" from the Start Menu. Open the print queue for your printer by double-clicking on your printer's icon. There will be a list of all the current print jobs. There you can right-click on a job and select Cancel, Restart, etc. Cancel will remove it from the list.
If you are not on the computer that is connected to the printer, you might not have permission to change the queue. Then you should go to the computer that is actually connected, and use this procedure there.
Posted on May 29, 2010
@Ananthara552--this happens to me quite often, too...and it is FRUSTRATING! After choosing "cancel " or "cancel all documents," the print job still doesn't cancel. The only solution that has worked for me has been restarting my computer and unplugging the printer.
Posted on Aug 15, 2011
    Problem Solver:
  • 20 Answers
Unplug the printer or hold the power button down.
Posted on Jun 03, 2010
Need to stop a print job from printing; in past, would go to Control Panel / Printer, and cancel. How do I kill print job in Windows 10?
Run a command prompt as Administrator
type
Net Stop Spooler
<Press Enter>
delete C:\Windows\System32\spool\Printers\*.*
<Press Enter>
Net Start Spooler
<Press Enter>
Close the command window
Feb 13, 2017 | In Office Equipment & Supplies
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
How do i cancel printing on canon 4370 dn
The surest way is to go to control panel, click printer, right click on your printer and cancel the printing or remove the printer cord, remove the power cord and cartridge (optional). And try again.
Good luck.
Jan 04, 2012 | Canon ImageCLASS MF4370dn Laser All-in-One...
I have an hp deskjet 845c printer. I hit the print button too many times and now it is printing multiple times. How can I cancel the printing? I have disconnected from computer, unplugged it but to no...
The print command is in que. You have to cancel it. The printer icon in task bar. Click it. when it opens you will see all the print commands. select eveny one and cancel from menu.
Jun 26, 2011 | HP DeskJet 845c Printer
Keep printing old docoments / will not print current docoment / printing seem to be strunt
Follow these steps to fix your problem :
Method A :
Press the cancel button or use the cancel menu command on the printer
The most obvious way to cancel a print job is to find a cancel button or a cancel menu command on the printer and to press it. So, if you have not already done this, try this method first.
If this method worked for you, you are finished with this article. However, you may want to read the "Prevention tips" section to avoid this problem in the future.
If your printer does not have these items or if this method did not work for you, try Method B.
Method B:
Turn the printer off and on
Next, try turning the printer off and then on. With certain printer models, this cancels the print job.
If this method did not work for you, turn your printer off, and then try Method C.
Method C:
Use Control Panel to cancel printing
This method is a bit fancier. We will use Control Panel to try to cancel printing.
But what exactly are you trying to do? Are you trying to cancel printing only a single document, or are there other print jobs that you want to cancel? And are all the print job yours, or are there print jobs that other people have sent to the printer? If you have to cancel documents that other people have sent to the printer, you must have Computer Administrator status or you must have permission to cancel the print jobs. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
To cancel one or more print jobs, follow these steps.
1. Click Start, and then click Run.
2. In the Open box, type control printers, and then click OK.
3. Right-click the icon for your printer, and then click Open.
* To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
* To cancel all print jobs, click Cancel All Documents on the Printer menu.
Note If you cancel a print job that you did want to print, make sure that you send the print job to the printer again.
If this method did not work for you, make sure that your printer is turned off, and then try Method D.
Back to the top
Method D: Stop the print spooler and delete all spooled files
If you tried Methods A through C and you were not successful, Method D should work for you. If you came to Method D immediately only to delete a print job, some of what we say here might not apply to you, so please bear with us.
Method D is somewhat more complex and will require a bit more work than the other methods, but don't worry. Method D looks much more difficult than it really is.
First, in case that you don't know how printing works, here is a short explanation. Print jobs are sent to the printer as spooled files. This means that the files are put in a temporary location so that the printer can access a print queue and print jobs at its own speed. If you stop the spooler and its files, most of the time, you both cancel printing and delete the print job.
Note To use this method, you must have Computer Administrator status. If you are using your own printer, you most likely have Computer Administrator status. If you are printing to a shared printer, you might have to ask the system administrator to cancel the print job for you.
Step 1: Start Notepad
To stop the print spooler and its files, we will have you create and run a script file that will automatically stop the service. This sounds difficult, but it really isn't. Just follow these steps carefully.
2. In the Open box, type notepad, and then click OK. Notice that a blank Notepad document opens.
Step 2: Copy a command script to Notepad
Now we will have you copy and paste some commands to the Notepad document.
1. Carefully select (highlight) all the following text:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
2. Right-click the text that you selected, and then click Copy.
3. In Notepad, right-click in the blank document, and then click Paste.
4. Carefully select (highlight) all the following text:
C:\DeletePrintJobs.cmd
5. Right-click the text that you selected, and then click Copy.
6. In Notepad, click Save As on the File menu.
7. In the File Name box, right-click, and then click Paste.
8. Click Save.
Step 3: Run the command script file
Now that you have created the command script file, you will run it. To run it, you will copy and paste the name of the command script file in the Run box.
3. Click Start, and then click Run.
4. In the Open box, right-click, and then click Paste.
5. Click OK.
6. Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
If this method does not work the first time, or if you cannot print anything after you use this method, restart your computer, and then try again.
Nov 20, 2010 | Lexmark X2500 All-In-One Printer
How do i cancel a print job?
Method A: Press the cancel button or use the cancel menu
loadTOCNode(2, 'resolution');
Method B: Turn the printer off and on
Method C: Use Control Panel to cancel printing
printing.
steps.
    • To cancel individual print jobs, right-click the print job that you want to
    • To cancel all print jobs, click Cancel All
If
future.
files
us.
it really is.
print job.
loadTOCNode(3, 'resolution');
    net stop spooler
    del
    del
    net start spooler
    File menu.
    then click Paste.
    Note Notice that
    this file name differs from most other file names that you might have seen. That
    is because this file is a command script file.
  8. Click Save.
    click Paste.
  5. Click OK.
    Run box.
Note If this method does
Oct 08, 2010 | Pitney Bowes AddressRight DA300 Printer
Print job won't cancel, window shows job is "deleting". Now nothing will print. It's been deleting for an hour. Is there any other way to clear print jobs from the cache?
Assuming a Windows OS (Win2K or above), you can kill the spooler queue from the run command line or in the command prompt window. Type "net stop spooler" (omit the quotes) and hit return. Then type "net start spooler" and return. Please note this will kill any fax monitor that you have running as well as the queue for all printers from your computer.
I strongly recommend rebooting the computer afterwards. If you do not run this in the command prompt window, entering only the first command requires a reboot and then a long wait for the action to finish.
I hope this helps.
Jan 05, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
My printer hp deskjet 3550 not working properly
my printer did not take the printing job. I wnt to cancel the job but it is not cancell lsat one job is still pending. If acctionally take the print firt two line is printing the rest of the matter is pending and that job is not able to cancel . I have hp diagnostic utility but it is also not working to release the printing que. kindly do needful to solve this problem
Jun 21, 2009 | HP DeskJet 3550 InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
191 people viewed this question
Seeker5211
Seeker5211
