Ge washer model#wjsr2080t6ww
The washer will not spin or drain, it also make a buzzing sound like a stuck motor when it reaches the spin/drain point in the cycle
  • 135 Answers
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Posted on Apr 07, 2008
I have a Frigidaire FTF530FS washer with a problem. The Timer gets stuck in between the drain and the spin cycle. It occurs when the timer dial is about 3 o'clock. I replaced the drain pump, the door...
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Feb 21, 2015 | Frigidaire FTF530FS Front Load Washer
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
My portable top load kenmore washer model 110.42722200 won't spin. It drains water and all the light functions work, but it only makes a humming sound like it is stuck when it gets to a spin cycle and does...
I just repaired this exact model this weekend. If the machine will drain but doesn't agitate or spin (you have to put a screwdriver in the lid switch to see), it's usually a loose belt. This time I replaced the belt, but it still would not agitate or spin, and the motor was not turning, just a "buzz, buzz, buzz" when the washer attempted to supply power to the motor. The start capacitor for the motor was bad. Part number 3429938 which runs about $60. Not hard to access once you tip the washer over slightly, just DISCHARGE THE OLD CAPACITOR so you don't get a nasty shock.
Aug 05, 2010 | Washing Machines
My GE WBSR3140D0WW top load washer fills, agitates but won't drain or spin
2 Possibilities. You have a failed drain pump, or the most likely, you have a clogged or obstructed pump or pump hose. it will n ot spin unitl the water level has reached a certain point. I have found socks in these. You will need to remove the front cover, slip a putty knife between the front cover and the top deck on the left and right side, push and at the same time pull the cover back. the drain pump is on the right side of the washer. If the pump sounds like its humming but not turning, there is something on the pump. If it sounds like its running, but no water being pumped out, then there is most likely an article of clothing stuck in the hose.
Apr 26, 2010 | GE WBSR3140DW Top Load Washer
My GE washer (mod WHSE5240D0WW) will not spin. It
sounds like the motor or the programer has packed up on you more (likley to be motor,) buzzing is the motor trying to turn but cannot,
Oct 26, 2009 | GE WHSE5240D Top Load Washer
My Whirpool Estate washer will not rinse spin or drain
The motor turns in one direction to wash and the other to spin. If it will not spin I feel sure it's a bad motor.
Please rate solution
Sep 04, 2009 | Whirlpool Washing Machines
GE front loading washer, WJSR2080T6WW, agitates, drains, wont's spin
might be a transmissin problem, ive seen the brake get too tight on these units to allow spin
Jul 07, 2009 | GE Profile WPRE6100G Top Load Washer
Washer does not "click" to drain and spin cycle
Hi, Check the lid switch. Most models will not drain or spin when the lid switch is bad.
If I can get the model#, I wil try and asist you further.
Jun 21, 2009 | GE Spacemaker Washer and Dryer Electric...
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
Washing Machines Logo
571 people viewed this question
Top Washing Machines Experts
