Question about Frigidaire Dryers
Need to cycle three times before clothes dry - Frigidaire Dryers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Morethan likely your vent is plugged with lint. the vent should be cleaned yearly to prevent fires and to provide maximum efficiency. move yoy dryer out and disconnect the vent from the dryer and inspect the hose for blockages. it can also be internally in the dryer along the channel the heat is vented through. clean out all the lint and try again. usually this fixes the problem. especially long vents or angles in the vent are more likely to plug up so remove those if possible after you clean it out. good luck. always unplug the unit while working on it.
Posted on May 28, 2010
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Needs two cycles to dry clothes!
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 19, 2012 | Kenmore Dryers
We have an LG DLEX8377NM dryer and are having problems with the drying cycle. We've owned it for three years and bought it new. It was professionally installed. We frequently dry clothes on the...
if there's heat in the dryer and yours is electric the most likely cause for dryer taking to long to dry is a blocked vent line,start the dryer ,go outside and check the outside hood where it blows out,make sure there isn't anything blocking it or a cage on it that's filled with lint,also every dryer should be opened up and cleaned,the easiest way is to get a shop vac,remove the front of dryer,vac up as much lint as you can see and then set the vac up to blow and blow the lint forwards so you don't have to remove the drum,then if the vent line is a long run i use a leaf blower,remove the vent line from the back of the dryer ,stick the leaf blower into the opening of the vent line and blow it out to the outside,hit it with short bursts at first so you don't damage the vent line if it isn't hard pipe,you will see a huge difference in the drying time.
Oct 01, 2017 | LG SteamDryer 7.3 Cu. Ft. 9-Cycle...
I have a Kenmore 67834 electric dryer, and it takes three drying cycles to dry a load of clothes, it just not heating.
your vent could poss be clogged up and needs cleaned. that could cause this problem 9 times out of 10.
Jan 27, 2011 | Kenmore 67841 Electric Dryer
Dryer is hot when opened, but takes 3 or 4 timed cycles to get clothes dry on very dry setting and timed setting
Check for a restriction in exhaust system,not just behind unit but all the way to outside vent,should feel warm decent airflow at outside vent.If not all you will end up with is warm moist clothes,You need good airflow to take away the moisture in the clothes not just heat.This issue can happen slowly over time and next thing you know its taking two or three times longer to dry even though when you open the door its hot inside.
Good luck
Aug 08, 2010 | Amana Dryers
Clothes not drying. need 2+ cycles to get clothes dry
Mar 30, 2010 | KitchenAid KEHS01P Electric Dryer
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
59 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
