Question about Garden
My Karcher 411A seems to have lost pressure. Behaviour is this, when you press the water release on the spray gun you get 100% pressure for like 10 seconds and then it seems to dwindle down to 30-40% of its total pressure. When the pressure cuts down I can hear more noise coming from the gun sprayer aswell. So not sure if the problem is in the gun or the main pump unit ?
  • 2,899 Answers
Sounds more like a clog on the intake side. Check the filter and the hose on that side.
Posted on May 30, 2010
Can't attach spray lance to spray gun
try some wd 40 or release the pressure in hose
Mar 18, 2015 | Karcher Garden
What is a bypass unloader
According to epowerwash.com:
"The unloader valve diverts water flow into bypass when the trigger gun valve is closed. Unloaders may be designed to respond to either an increase in pressure or a change in flow. The unloader valve may also be used for variable pressure adjustment."
More information here:
All About Unloader Valves ePowerWash
Jun 06, 2014 | Alfred Karcher Pressure Washer
Water leaking from spray gun
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Jan 02, 2011 | Karcher Garden
Vacuum lock when releasing trigger. water will
It sounds like the valve in your trigger gun is sticking. Depending
on the model it can be rebuilt or repaired
Sep 08, 2009 | Karcher Garden
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
My karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Apr 25, 2009 | Karcher Garden
Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Mar 07, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
565 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
