Question about Kenmore Heating & Cooling
I was given a large kenmore air conditioner (model # 253-355350) but have no idea of how many BTU's. I would like to know how large an area it will cover. Any ideas please?
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
  • 67 Answers
SOURCE: how large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Posted on Jul 21, 2008
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
skrbin
  • 121 Answers
SOURCE: what startup surge Watts required for 5000btu Air Conditioner
1.5kW
Posted on Feb 17, 2009
  • 659 Answers
SOURCE: No installation manual for new air conditioner
Here you go...........
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FAS257S2A&User=&Search=Search
Posted on Mar 31, 2009
Model 25373156301 air conditioner: What are the dimensions? How many BTU? Last year they were manufactured?
Found very little on that model: Kenmore 25373156301
24 in. Wide, 18 in. Height, 24 in. Depth and approx. 112 lbs.
15,000 BTU, Parts are still available.
Unknown date(s) of manufacture but Sears (Kenmore) does have similar (exact matches) models still in production.
Sep 13, 2014 | Heating & Cooling
HOw to fix portable air conditioner? It is leaking
Unless it is leaking the refrigerant then what is dripping is the condensation air conditioners produce. This being a portable, it should have a drip pan that can be removed and drained. Window units just drip out the back and large units have a hose routed to drip away from the unit or into a drain.
Sep 06, 2014 | Kenmore Portable Air Conditioner 10000 BTU...
I'm having problems finding out how many BTU's my Kenmore 580.70188000 is. Does anyone know?
It's a wall unit, 208/230 Volt, it's 17,500/18000 BTU. It says that up by the inside exhaust when you take the cover off. I'm looking for a manual.
Jul 19, 2011 | Kenmore 75085 Air Conditioner
Model 25370186000 therostat will not reset stuck on 50
try unplugging it and see what happens it should reset I'll bet it's a bit nippy huh>?
Jul 19, 2011 | Kenmore 18,000/17,500 BTU Large Capacity...
How many BTU is Model#580.74085 580.74124
8000 BTU. I have one. I'm looking for the EER rating, although I see an energy star label on the front.
Jun 19, 2011 | Kenmore 75135 Thru-Wall/Window Air...
After my air conditioner is on for awhile it will automatically shut off completely then after a few minutes it comes back on. It is not set on the energy saver setting. Also it is and continues to do...
Debi, it;s not unusual for an AC unit to turn ON & OFF. Once it reaches the temperature that you have it set ON and holds the temperature for 4 or 5 minutes, it will shut OFF until the room temperature rises above it. Be sure all the doors and windows are closed and no hot air is infiltrating the area.
Also, a 10,000 BTU air conditioner is not designed to handle a large area. Generally, 10,000 BTU's will handle about 3200 Cubic Feet (20' x 20' x 8' = 3200 sq ft) or simply put, 400 square feet. Your A/C unit may be undersized for the area you're trying to cool.
Hope this helped you. Please let me know. Thanks.
Jun 07, 2011 | LG Electronic Window Air Conditioner
Working with 220 v
If you are looking for a "window" type of unit yes there are some 220 volt units on the market. Most are large like 18,000 btu or larger. Check Lowes, Home Depot or larger appliance retailers for availability. Also know when buying if you need a heat strip, or heat pump if indeed you want heat.
Nov 15, 2007 | Kenmore 75085 Air Conditioner
Heating & Cooling Logo
61 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
