Question about Kenmore 47783 Electric Single Oven
Burned foil on bottom of self-cleaning oven. Please help!!!!
  • 327 Answers
Hello,Take some mild soap and water and lightly rub it in with a scouring pad. This should remove most of it if not all of it.
Thanks
Posted on May 28, 2010
4 Suggested Answers
  • 1314 Answers
SOURCE: tin foil stuck to bottom of oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Posted on Dec 29, 2007
  • 10865 Answers
SOURCE: I have a Kenmore self cleaning oven with foil liner burned on!
Hi Leia, Unfortunately, the aluminum actually melted and adhered. The only perfect fix is to buy a new bottom piece for the oven, it costs about $30.00 and it is very easy to remove the old and install the new. Just a few screws.
You can get the part directly from sears by going to sears.com
Posted on Jun 02, 2009
Obertelli
  • 3006 Answers
SOURCE: I have baked on aluminun foil on the bottom of my
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
Posted on Sep 20, 2009
Is the oven self cleaning and if so how does it work?
if its self cleanin it will say right on it "self cleaning"
self cleaning ovens do exactly that they clean themselves no harsh chemicals (oven cleaner foam) are needed to dissolve the baked on cooking goo that builds up inside ovens , although if one uses a foil liner in bottom then one might never need to self clean it , but some models cant use liners due to convection fans air flow getting in the way ,
self cleaning ovens have the ability to get very hot (500 degrees plus) no one should ever open a oven in cleaning cycle as this hi temp can spontaneously combust to ashes your hair/clothing never the less burn the hand that opened it severely(most lock the door for safety) all that needs done after cycle, is ashes need wiped out with damp towel next day after cleaning cycle is done and oven cooled off completely , im waiting on the day they make one that sweeps its self out into the dust bin ,(not yet )
Sep 26, 2015 | Ovens
1How do I remove small pieces of aluminum foil which are stuck to the bottom of my oven? 2 If I can't remove the small amounts of alum. foil, Will still be able to use the self-cleaning feature?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
You can try to use a putty knife.
When your oven goes into the self cleaning model, you are burning off grease. The burning off of aluminum foil is nothing compared to burning off the grease.
You may see some small flame. But, this will soon pass. Your cleaning cycle can handle this without causing any damage.
Mar 24, 2015 | Kenmore Ovens
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
Some aluminum foil melted onto the bottom of my Kenmore Elite oven, which happens to have a hidden bake element. I happened to catch that this was happening to remove most of the piece of foil, however,...
Don't use self clean. Get some easy off oven cleaner. Self clean gets too hot and ruins expensive delicate electronics.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 07, 2010 | Ovens
I have baked on aluminun foil on the bottom of my self clean oven did the cycle to self clean and the aluminum foil is still stuck on the bottom what can I do to remove it without ruining the surface
Sep 20, 2009 | Electrolux ICON Designer E30SO75ESS Oven
May 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Melted aluminum foil on bottom of oven
Steel wool is the best bet, but it would be easier to replace the floor panel. I had a customer do the same thing. depending on how bad it is replacement mat be a easier option, about $35 for the new panel, and about a month to get the part. two screws on the floor of the oven next to the back wall. The manual does say not to use foil on the oven floor.
Apr 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Tin foil stuck to bottom of oven
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47783 Electric Single Oven Logo
179 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
