Question about Bose Lifestyle SA-3 2-Channel Amplifier
How can I conrol the volume of bose sa 3 amp from the aux input ?
How can I increase the volume of bose sa 3 amp from the aux input without the VCA accessory - so that I can manage it from a classical stereo preamp ?
    Brigadier General:
  • 8,546 Answers
That would depend on the preamp. Name it. A true preamp outputs a variable signal.
It's not clear from the manual what the state of the volume output is without the VCA. Most amps default to full ON and the preamp attentuates the signal with a volume control. Try it with a signal that fades in slowly so you can intervene if it gets too loud. If it's full ON a preamp will control its volume.
Posted on May 29, 2010
My Bose SA3 2 channel amp keeps blowing when I raise the volume with non-bose speakers, why is this happening?
Could be the impedence of the speakers that you're connecting. The bose amp was designed to drive 8 ohm speakers.
Aug 31, 2016 | Bose Lifestyle SA-3 2-Channel Amplifier
I have a Stanton T60, but I connect to my Bose, but my bose has no phono input, tried aux but low volume... Do I need to buy a preamp?
You don't need a PRE-amp but you do need an amplifier. The auxiliary plug on the Bose is only for iPhones etc which have a margin of their own amplification which your turntable has none. The phono plugs are for the turntable to supply a low power signal to the amplifier to boost it to be audible at volume.
Oct 06, 2015 | Stanton Audio Players & Recorders
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
I plugged my adator jacks into the aux port and no sound
check that the input source it set to aux on the bose. to check it is on turn the volume up a bit and touch the contact end where you plug into the source. it should gently hum when you touch the connectors then you know that the input is live on the bose. i take it you have it switched on lol
Apr 09, 2011 | Bose 3 2 1 Series I DVD Home Entertainment...
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
Bose SA-3 amp and a non bose sub.. I keep blowing the amp..
How many ohms is your sub? The SA 3 Amp can only handle speaker(s) 6 ohms and greater. A lot of subs, as I understand, are 2 and 4 ohms typically. If yours is 2 or 4 ohms, then that explains it. The speaker would be "straining" your amplifier and blowing it.
Oct 02, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Bose SA2 distortion
As the distortion is on both channels it must be something to do with something that is common to both!
My guess is an IC. Check to see if it uses an IC for the main amplification. They are big with loads of pins coming out of them. Sometimes marked STK and then a number. If you find one it will have gone! Replace it with the exact part.
May 04, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Bose 151 main with amp
Does your tv have stereo outputs? if yes all you have to do is run RCA red..white jacks into tv outtput then run the other ends into the amps tape or aux or cd input and your done! If you dont have outputs on tour tv you will have to but an RF converter box (about 20.00 at wal-mart) and hook that into the tv and the cables will run out of that to the stereo!
Jan 14, 2009 | Bose 901 VI Main / Stereo Speaker
Bose Lifestyle SA-3 2-Channel Amplifier Logo
1,152 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
