Question about Soltek SL-NV400-L64 Motherboard
Hi, Am after Chipset nVIDIA nForce2 400 + MCP Processor AMD Socket 462 on board. Front Side Bus 400/333/266MHz Front Side Bus. Memory 2 x 184-pin DDR DIMM Sockets. any idea's please
  • 11,800 Answers
Only on second-hand sites like ebay. Example of a similar but better one
http://cgi.ebay.com/Abit-AN7-Nvidia-NForce-2-400-Ultra-AMD-Athlon-XP-2500-/330435195881?cmd=ViewItem&pt=Motherboards&hash=item4cef78f3e9
Posted on May 28, 2010
Testimonial: " my fault, did not ask correct Question. am after driver for this board"
  • Azrael SRL May 28, 2010
    For the chipset get it directly from nVidia. The drivers for the sound and lan can be downloaded from the site of their manufacturer
Processor upgrade
WHERE IS THE QUESTION.
Feb 24, 2015 | Max Computers & Internet
Memory settings for ddr
http://www.motherboards.org/mobot/motherboards_d/ECS/K7AMA/
Since the Processor Front Side Bus (FSB) support is 200 or 266MegaHertz (MHz), the ram memory will be DDR Sdram at either 100Megahertz or 266MHz.
That is PC1600 and PC2100, respectively.
2GB's maximum TOTAL amount for motherboard.
1GB per ram memory slot - Maximum
If you have a Socket A (Socket 462) AMD processor with a 200MHz FSB, I suggest DDR Sdram at 100MHz. (PC1600)
AMD processor with 266MHz Front Side Bus = either PC1600, or PC2100. I would go with PC2100.
Voltage in BIOS Setup is 2.5 Volts. That is is the JEDEC standard voltage, for DDR Sdram.
Ram timings will be dependent upon what the ram memory supports.
IF you have just ONE ram memory module ('Stick'), it goes in Slot 1.
(DIMM 1)
This is the ram memory slot the Processor reads first.
http://www.cpu-upgrade.com/mb-ECS/K7AMA%28V1.5%29.html
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/ecs_k7s6a_vcore.html
http://8000.hillbillyhardware.com:8000/Reviews/ecs_945gcd-m/ecs_945gcd-m.html
"When it comes to innovative motherboards ECS is not a company that first comes to mind. Not since the days of the K7AMA that offered DDR266 and PC133 memory options for AMD's K7 line of processors has ECS released a motherboard that has filled a gapping hole in the PC hardware market space. Lets just hope that the failure rate of the 945GCD-M is nothing like the failure prone K7AMA."
Hmmmmm,
Not doing it for you? Then post more details in a Comment.
Regards,
joecoolvette
Jan 03, 2013 | EliteGroup K7AMA Motherboard
Need the pin Config for the Motherboard pwr switch and hdd switch for a Emachine T2672 and pwd led thanks
Pin Configuration = Pinout
The Front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables (Wires) go to, is the Front Panel header.
Front Panel header pinout.
The motherboard used in an eMachines T2672 desktop computer is an FIC AU31 motherboard.
Made by First International Computers (Inc.) for eMachines.
http://www.e4allupgraders.info/dir1/motherboards/socketa/au31.shtml
Orient the motherboard like it is in the photo, so we are both looking at it in the same direction.
{Processor to the top, Ram memory slots to the right, white PCI slots to the bottom. The way it sits in the computer case}
The Front Panel header, is a small black rectangular block that sits horizontally, at the far right bottom corner.
It has two rows of pins.
4 across the top, and 5 across the bottom.
(The small rectangular block above it, is for connecting a Power On LED light that has 3 wires. More on this in a moment)
The pins are numbered.
The pins are numbered Evenly across the top, and Odd across the bottom.
Starting from the Left side going across to the Right, on the Top row;
Pins 2, 4, 6, and 8.
There is No Pin 10.
Starting from the Left side going across to the Right, on the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
Pin 1 is for the Positive wire ( + )
(If the LED light is dim when operating, switch the wires around)
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Reset button)
C) Pin 9 is Not Used. (NC. No Connection)
D) Pins 2 and 4 are for the Power On LED light, IF it is a 2 wire LED light.
Pin 2 is for the Positive ( + ) wire.
(If the LED light is dim, switch the wires around)
If the Power On LED light has 3 wires:
Use the Power On header above the Front Panel header.
This rectangular block has 3 pins.
Starting from the Left side going to the Right; Pins 1 , 2, and 3.
Pin 1 is for the Positive wire.
Pins 2 and 3 are Ground wires.
E) Pins 6 and 8 are for the Power On switch. (Power On button plastic assembly has an ATX power on switch inside it)
This is a link to a free motherboard manual, for the FIC AU31 motherboard. It is in Zipped file form.
(A Zipped file is a compressed file. It is used for one, to send a large file over the internet)
If you do not know how to unzip a file, post in a Comment, and I'll lead you step by step.
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
In the list on the left side, left-click right on the file name - AU31
For additional questions please post in a Comment.
Regards,
joecoolvette
[ P.S.
The motherboard chipset is an Nvidia Crush 18G + MCP AGP
It is an Nvidia Force 2 chipset,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#nForce2
Supports Processors that are AMD, and fit in a Socket A processor socket.
(Socket A is also known as Socket 462)
Supports AMD processors that have either a 200MegaHertz Front Side Bus, or a 266MHz FSB, or a 333MHz FSB.
AMD Athlon XP processors with either a 266MHz FSB, or 333MHz FSB.
From the 1500+ model up to the 2800+ model.
AMD Duron processors with a 200MHz FSB.
From the 800MHz to the 1.3GHz models
(AMD Athlon XP is the top of the line. Then it's Duron, then Sempron.
A Sempron processor has half of the L2 cache that a comparable Athlon XP does)
Ram Memory is DDR Sdram at either 200MHz, or 266MHz, or 333MHz, or 400MHz.
Depends on the Processor used.
(Ram Memory typically operates at half of the frequency rate ('Speed') that the Processor does.
If the processor's FSB is 333MHz, you can use 400MHz DDR Sdram. {PC3200}
Confusing I know.
DDR Sdram is 'double-pumped'. It is actually 200MHz for PC3200.
This is close to half of 333MHz.
Processor has an FSB of 266MHz? Ram memory used will be 266MHz. Remember, it is actually 133MHz for the ram memory. (PC2100)
Need an AMD Athlon processor?
I found this place years ago. Not advertising for them. Just computer geeks sticking together, and sharing information. (I have bought a motherboard from them, and it works fine),
http://www.weirdstuff.com/cgi-bin/category/10201
Sep 04, 2011 | E-Machines eMachines Desktop PC
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
Aug 30, 2011 | DFI LANPARTY UT nF4 Ultra-D Motherboard
CAN U PUT 2 GIG OF RAM INTO THIS MOTHERBOARD
Yes you can.
Your main board has the following type of ram:
2 x DDR SDRAM PC3200, 2GB max 400/333/266MHz
Part Number EP-8RGMI Manufacturer Epox Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset Nvidia nForce2 IGP+MCP North Bridge Nvidia nForce2 IGP (IGP128 v2.0/400) Socket Socket A (462) Processor Types Athlon, Duron Number of CPUs 1 Front Side Bus 400/333/266MHz Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP Nvidia GeForce4 MX South Bridge Nvidia MCP Audio 6-channel IDE 133/100/66/33 SCSI None SATA None RAID None LAN 10/100 Firewire None USB USB 1.1 Expansion Slots
  • 1 x AGP
  • 2 x PCI
Drivers
  • 1 x AGP
  • 2 x PCI
Aug 29, 2011 | EPoX EP-8RGMI Motherboard
K7SV266AD Can I use 266Mhz athalon processor with this board, book says 100/133 FSB. If so what processors? Thanks
The Syntax K7SV266AD motherboard uses a VIA motherboard chipset.
It uses a VIA KT266A for the Northbridge, and a VIA VT8235 for the Southbridge.
About the motherboard chipset;
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
The Northbridge chip handles the faster capabilities of the computer.
It handles the Processor, Ram Memory, and High-speed graphics.
High-speed graphics is AGP or PCI-Express
A graphics card inserted into a PCI slot is Not high-speed graphics.
Neither is Integrated Graphics.
(Integrated Graphics is also referred to as OnBoard graphics.
ON the motherBOARD. The graphics chipset is soldered directly to the motherboard, and not to a graphics adapter card. {Graphics card}
The graphics chipset is a GPU.
Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
The Southbridge chip handles the slower capabilities of the computer.
It handles the IDE, and SATA capabilities of the computer.
It also handles the USB ports, Ethernet, and Audio, plus anything connected to a PCI slot, and Integrated Graphics, to list a few examples.
Motherboard Diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
[For further information you may wish to search on Wikipedia,
A) Northbridge (computing)
B) Southbridge (computing)
C) Bus
D) PCI Local Bus
E) AGP (Accelerated Graphics Port)
F) PCI Express
G) Front Side Bus ]
Looking at the motherboard with the Processor to the top, and Ram Memory to the right, the VIA KT266A northbridge chip is below the Processor.
The aluminum finned Heatsink covers it.
The VIA VT8235 southbridge chip is down towards the lower right corner.
Looking at the specs for the VIA KT266A chip we can see,
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
1) It supports either DDR Sdram ram memory at 200MegaHertz, or 266MHz.
PC-1600 or PC-2100, respectively.
(DDR Sdram is clocked twice. Therefore the 133MHz Front Side Bus {FSB} support will handle 266MHz ram memory)
2) The Maximum ram memory it will support is 4GB. If you have the motherboard manual, you will know what the maximum amount of Ram Memory is, that the motherboard will support.
3) Will support Processors with either a 100MHz, or 133MHz FSB. (Front Side Bus)
AMD processors are 'Double-pumped'.
The VIA VT266A chip will handle AMD processors with up to a 266MHz FSB.
It will handle AMD Athlon, or AthlonXP, or Duron processors, with a maximum FSB of 266MHz.
http://www.via.com.tw/en/products/chipsets/legacy/kt266a/
The best processor will be an AMD AthlonXP with a 266MHz FSB, that fits in a Socket A (Socket 462) processor socket.
Watch the Voltage used. Look up the AMD processor you have installed now, and see what voltage range it uses. The new processor must use voltage in this range also.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
For additional questions please post in a Comment. (Upper right of your page)
Regards,
joecoolvette
Jul 04, 2011 | Syntax Computers & Internet
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
I need specs
Here is the specs of the mobo.
Product MPN MPN sv266m Key Features Form Factor dtrquestion.gif Micro ATX Compatibility PC Chipset dtrquestion.gif VIA ProSavageDDR KM266 Compatible Processors AMD Athlon Processor Max supported CPUs qty 1 Memory Memory Type dtrquestion.gif DDR SDRAM Max Supported RAM dtrquestion.gif 2 GB Audio / Video Audio Output dtrquestion.gif Sound Card Video Interface dtrquestion.gif AGP 4x Communication Networking Type Network adapter Other Features Chassis Type dtrquestion.gif Desktop Package Qty 1 Dimensions Depth 9.52 in. Width 8.97 in.
Dec 03, 2009 | Syntax SV266M Motherboard
Soltek SL-NV400-L64 Motherboard Logo
292 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
David
David
Paul Bade
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
