Question about HP vs19 (Silver) 19" LCD Monitor
Problem with HP VS19E monitor
I'm having the same problem. How easy is it to replace the capacitors and where can I buy them?
I can't seem to find the fan7601 vf48 anywhere.
Posted on May 10, 2008
  • 180 Answers
You buy it at all electronic shop.
Posted on Apr 09, 2008
Hp vs19e lcd sreeen stoped working power light button does not come on, the monitor is around 4 years old is it worth fixing or time for new one?
If you have it repaired by the shop then it will not be worth it, if you want to DIY repair then you need to buy proper tools.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 06, 2010 | HP vs19 (Silver) 19" LCD Monitor
My HP vs19e monitor takes almost 5 minutes to "wake up". Works fine once running. It never took this long before. Any ideas?
most common problem is bad electrolytic capacitors if unit is a few years old. Take it apart and replace any swollen, ie bulging top of the aluminium can... but may be 'off-value' if not swollen. Any electronics from China will fail within 3 years due to bad electrolytic caps..
Sep 07, 2010 | HP w19 19" LCD Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs19e Flat Panel Monitor. model HSTND-2LO7, product# EN632AA made March 2006. I have no power indication. Checked internal power supply connections and PC mounted fuses. Tested operation with another...
If it's under warranty, then take it back for repair or replacement. If it's not under warranty then plan to buy a new one. Unfortunately, in the modern world, faulty electronics without a warranty on them are becoming increasingly known as "throw away items". This has started to happen with monitors. They call them throw away items because it typically costs just as much or more to have it repaired as it does to replace it with a new one. There are several things that could cause the monitor to go black: Bad inverter, Bad back-lights, Bad throwback (transformer), Bad LCD, & etc. Look for any burned resistors or popped capacitors on the circuit boards also. I've had a few monitors where all I had to do was replace the faulty resistor or capacitor and it worked fine.
Mar 22, 2010 | Computers & Internet
HP vs19e monitor is blank. Power button is slowly
that is not a monitor problem that is a cpus problem disconnect the signsl cable and connect power cable you will see the post (power on self test) open the cpu draw the ram clean the dust and reinstall the problem will solved
Feb 26, 2010 | HP vs19 (Silver) 19" LCD Monitor
I want to replace the power switch board on my hp vs19e monitor.
About your only hope for getting a replacement switch is to buy a "Parts Only" monitor off of EBay and carefully remove the switch. This one is tricky it's attached to the front bezel as you've likely found out. When you disassemble the monitor, lay it face down and remove the bac plastic then remove the 4 screws holding the button board on then take the rest apart. That's the safest way.
Mar 28, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Hp vs19e just died
those capacitors are polarized they have a neg and a pos side were they seated correctly? could also be transistors going bad but my bet is some cap was in backwards.
Mar 22, 2009 | HP w19 19" LCD Monitor
I replaced the 3 capacitors now there's just bright white screen
Open your monitor back up and look for unplugged connectors, especially the one to the back of the LCD. I had this same problem with a HP F1703. The owner whacked it so hard when the backlight stopped that they dislodged the connector.
Feb 27, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
HP VS19e Monitor - no power
There are three (3) capacitors that go bad on the power supply board. MAKE magazine's Instructable site has a good guide on replacing them. I have a june 07 and july 07 date monitors. they were different inside!! identical outside, however. The bulged,'bad' components were 1000uf 10v cap's, I put in radio shack 272-1032 1000uf 35wvdc. My monitors? BOTH were bought for $35 on craigslist, $10.35 in parts. ???BusinFLA -at- hotma*l dot com.....worked for me!
Jun 14, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP vs19 (Silver) 19" LCD Monitor Logo
170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
