Question about Sanyo PLCXU30 Multimedia Projector
Sanyo plcxu30 turns itself off after 20 minutes
My plcxu30 is quite old and the lamp has needed replacing for a while now. Recently it simply turns itself off after around 20 minutes use. Is this due to the bulb or does it sound more serious. The unit is in no way overheating.
Please help !
[email protected]
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
This can be caused by the lamp, the older it gets, the more current it needs, so the lamp supply will shut down!!
even a bad capacitor on the power supply can be the cause ( 2.2 uf > 105 degrees)
Carefull : never remove the cover/ put it back when PJ is on or in standby!!
a short circuit can easily be made with the edges of the cover.(metallized).
Posted on Sep 26, 2008
SOURCE:
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
My tv turns on and off. It will stay on for about 3 min and then turn off. What is the problem??
If its Sony KDF-50WE655 TV then its weak lamp symptoms like TV turns off and on automatically and work for 3 minutes as you mentioned.
How old is this TV and did you replaced lamp recently?
Replace its lamp that is weak in result and causing TV off and on itself.
Lamp replacement procedure is written in user manual, very easy, click Sony Support to download copy, if required.
Please buy Sony original lamp for TV safety that is available in Sony Accessories Store under following part number for $200
A1606034B... LAMP BLOCK XL-2100U
If model number is different, let me know.
Thanks.
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Convergence error Sanyo PLCXU30 proyector
this can only be solved by mechanical readjustment of the blue lcd panel .
be extremely carefull doing this!! a small move means 1 cm or m ore on the sreen
Sep 26, 2008 | Sanyo PLCXU30 Multimedia Projector
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
