Question about Sony Audio Players & Recorders
With my amplifier sony TA V902 I don't have sound out from any source.
  • Sony Master
  • 17,130 Answers
When you amplifier is powered on if the speakers are powered on and you hear that the output is switch on then it is possible that the fault of the amplifier is in the preamplifier.Open the set and check on the input of the amplifier with a signal . If there is output the fact is confirmed of the preamp stage. Now we have to confirm if the fault is in the source swtiching or the preamp equaliser/ tone section. Using a good signal tester and hoping that you are familiar to handle the electronics inside, the IC can be identified and changed. Use extreme care and test at low output, Use a help of an expert to signal trace the fault. Hope I could help. Good day
Posted on Jul 24, 2010
Sony TA-AX401 powers on but no sound from any of the speaker inputs
its peotected if no signal is in serted you ahave to put in a audio source to make the relays on
Jan 30, 2015 | Sony Audio Players & Recorders
Sony lbt v902
I jst wanted a manual or picture to see how i can connect the pieces
May 18, 2013 | Audio Players & Recorders
I have a Sony power amp TA-N9000es there is no sound do you need a remote or is there a volume control inside the case. Have tried every input every speaker connect there is just no sound. what can i do...
It's just a big amp with no controls you would change during normal operation. There's no remote. You don't name any source or if you even HAVE one attached. THAT would be a good place to look for missing sound.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/sony/sony_ta_tan9000es.html
http://dl.owneriq.net/f/fede44fb-b9ba-4e03-87bb-d0f3e29e22ef.pdf
Set the BTL/Normal switch on the back to Normal. In fact, any switch or knob with BTL, set it to whatever choice is NOT BTL.
Mar 24, 2011 | Sony TA-N9000ES 5-Channel Amplifier
Sony TA-E9000es. No Display, No Sound. Software Ver 1.18. Has Bulletin HIFI1-99-028R1 performed. (Add capacitor, replace resistor)
also replace Q108 @ Q109 on power board. If that does not fix it then also replace PH101 & PH102. Also on Power board.
Jan 14, 2010 | Sony TA-E9000ES Amplifier
How to hook up equalizer to the amplifier
always remember source, amp, then speakers. ex: cd to eq to amp to speakers and it goes: out from cd player into eq, out from eq into amp, out from amp into speakers . hope this makes it easier for you.
Jun 23, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
HOW TO WIRE AN EQUALIZER TO A SONY TA-FE370 AMP
You can't wire an equalizer to this amp unless you only want to equalize one source, because it doesn't have a tape monitor function.
Jan 22, 2009 | Sony TA-FE370 2-Channel Amplifier
Sony TA-AV421 Amp
im needing help connecting my audissey aps 5+2 energy floor speakers . im confused on the 2 channels
Jul 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
RX-V902 TV/DBS source coming through all other sources...
This could be as simple as having input and output line audio reversed. Please check all sources for proper connection. You can do this at the receiver too, but not both receiver and sources.....accordianman
Oct 31, 2007 | Yamaha R-V902 Receiver
Sound problem on Sony TA-343 amplifier
If you're not experienced with troubleshooting and repairing electronics, I strongly suggest professional service. There are internal problems and most likely several components will need replacement.
Oct 08, 2007 | Audio Players & Recorders
297 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
