Question about Grundig Digta 410I Digital Recorder (32 MB 45 Hours) Handheld Digital Voice Recorder
Digta 410 fat error
Hi
I have a FAT error on mt grindig digta 410. I cannot clear the error or download
  • 43 Answers
Try formatting the memory - or try using an external memory card (SD).
Posted on Jun 07, 2010
Error code 4
If the fat that youre talking about is one solid color it could be grease essential to the operation of the dishwasher. Otherwise it may be food matter and the like. If that's the case, clear this out by hand, reassesmble, and run an empty load and check for leaks. Also, clean your dishers a little better before putting in the washer.
Good Luck
Dec 05, 2013 | Dishwashers
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Where can I find manuel for model 681 DQ 63
http://www.healthometer.com/Manuals.aspx
^ This should be what you're looking for. Click the second link that says "Wt. Tracking & Body Fat" and then click the "BFM.." link. You need adobe or a similar program to open the .pdf file. This shouldn't be an issue but if you can't open it, you can download adobe here: http://get.adobe.com/reader/
Mar 12, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
Hi change kg to lbs
There should be a small switch on the back that allows you to select between kg/lb/stone.
Mar 05, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
Sansa fuze FAT error
Plug your Fuze into your computer. Open "My Computer," right click your Fuze and click "Format," a window will pop up with settings on how you want to format it, make sure it's set to FAT, then click "Format."
May 09, 2009 | SanDisk Sansa Fuze MP3 Player
N-card error
Depending on what type of card you have, you need to go to the appropriate website and download the latest software files.If the card takes a memory card you may also find formatting the card with the fat 32 system more reliable and this may get rid of the Open fat error also.
Hope this helps
Aug 03, 2008 | Nintendo DS Lite Console
Grundig Digta 410I Digital Recorder (32 MB 45 Hours) Handheld Digital Voice Recorder Logo
129 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
