My ge washer Model# wjsr2080t6ww will not spin or drain
    Genius:
  • 3,422 Answers
HI,
The washer won't drain:
WARNINGS:
  • Unplug the washing machine while you are working on it to prevent injury from electrocution
  • Be prepared for water spilling on the floor.
Method:
There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is sliping or broken.
  1. Fill washer with water and wait for the timer to get to the drain mode.
  2. Unplug the washer from the electric outlet.
  3. Open the case, and disconnect the water hose from the outlet of the water pump.
  4. If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
  5. Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
  6. Reassemble hose from step 3.
  7. Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
  8. Reassemble washing machine case...you're done...
The washer won't spin:
WRNINGS:
UNPLUGG THE WASHING MACHINE FIRST
METHOD:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 07, 2008
  • 818 Answers
Washing machine model #wjsr2080t6ww how do i get the agitator off
This youtube video will show ya who to remove tha agitator (and replace the agitator coupling)
http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Aug 26, 2011 | GE Washing Machine Lid Strike WH1X2734
I have a g.e. washer model wjsr2080t6ww and it is leaking water from underneath
There are 4 common possiblities. 1. Hose from tub to pump has a hole in it
2. Water pump is leaking
3. tub seal has gone bad
4. Water fill manifold has a hole in it
1,2,4 is an easy fix
3 requires removal of the inner tub (not an easy job)
May 15, 2011 | GE Washing Machines
GE washer model WJRE5550K2WW - will fill water and drain but does not agitate and spin.
It new to me I am working on a GE washer model wjre5550k2ww it fill but not washing I can put it into the spin and it release the water but do not spin
Jan 05, 2011 | Washing Machines
My GE Washer Model # S2100 will not spin dry every thing els works
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 22, 2010 | GE Washing Machines
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE front loading washer, WJSR2080T6WW, agitates, drains, wont's spin
might be a transmissin problem, ive seen the brake get too tight on these units to allow spin
Jul 07, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer will not go to spin cycle or drain.
Possible lid switch not fully engaged. It will no drain or spin if lid switch is not fully engaged. I would also check the drain line for pluggage.
Oct 22, 2008 | Washing Machines
Ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Apr 07, 2008 | Washing Machines
Washer machine problem
The problem was two out of three broken spider arms. Shame shame on GE for using Frigidare parts and using aluminum for a washer part in the fist place, also not listing the matinance needed to clean the filter in their manual. So they can come clean it for you, at a cost of $69.00? Seems so. And refushing to sell the broken part separate from the drum. Though the part itself was under warranty we had to pay for the labor of a poorly manufactured part that is a well known issue. See (Why Kenmore front load washers fail) on You Tube. There is a nice video of the spider arm SCAM!!!!!! We need to speak out together or the problem will continue.
Apr 06, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
