My HDD/DVD recorder will not format discs.
No matter which brand of which type of recordable disc I try my HDD/DVD recorder refuses to format them. I've cleaned the laser at least twenty times and everything else works perfectly.
  • 11,800 Answers
You can format only RW disks. If you are using R (recordable only once) disks you don't need to format them, just burn directly the movies.
Posted on May 28, 2010
Testimonial: "Thanks for the help :)"
Where can i get a free user manual for my hdd dvd recorder
Hello Carol,
I can help you get it. Just reply here and indicate the brand and model of your HDD DVD recorder so I can look for it and give you the link where to download it.
Oct 18, 2011 | Televison & Video
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
Sony dvd rdr gx300 failure to delete discs
You can delete titles on a DVD+/-R, but it will not free up disc space. These are not "rewritable (RW)" disks.
To reuse discs, start with a DVD +/-RW. Be sure to format it "VR," not "Video."
http://esupport.sony.com/perl/model-documents.pl?mdl=RDRGX300
Oct 12, 2008 | Sony RDR-GX300 DVD Recorder
I bought a Magnavox 810H 160GB HDD/DVD recorder. It's a decent machine which worked perfectly for a few months, but now I can't get it to record to DVD. The HDD recording and playback functions work fine,...
Try switching it over to DVD . Because you may still have it on HDD when you put the disc in it may be that the unit is still thinking you are on HDD and don't recognise it as a disc just the hard drive
Sep 11, 2008 | Televison & Video
Rec from hdd to disc
Only use one of the disc types that is listed in the manual that they have actually tested on unit. If the HDD recordings were made in HQ mode, then you will only be able to fit a one-hour or less recording on a DVD. You cannot reverse this at this point. For future HDD recordings, set the record mode to 4hr or higher.
Jul 20, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Disc read error
Sounds like the laser has gone or the try is not fully loading the disc.
Dec 03, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Electro Med Services...
