Question about Miele Novotronic Premier 500 Front Load Washer
After cleaning fluff filter water is leaking Out of drain fixture
After cleaning filter water is leaking out of the front area where filter tap is
4 Suggested Answers
  • 82 Answers
SOURCE: water leaking
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it
ie a crack in the plastic allowing water to escape
Posted on Jan 16, 2010
  • 177 Answers
SOURCE: I cleaned out the fluff filter on my Miele W1918
hi,
the fluff filter just needs hand tightening up a bit more to stop the leak. if not there could be a bit of fluff trapped between the seals. Remove it again and have another look. Make sure also you don't cross thread the fluff flter which makes it feel like it is screwed in properly when it isn't
Posted on Jan 19, 2010
rickead1
  • 1998 Answers
SOURCE: When the washing machine is turned on the machine
if the machine is not filling then this would be an issue either involving the water valve or the pressure switch in the unit. Remove the 2-3 screws along the back that hold the top panel to the back frame. you would then slide the upper cover towards the rear of the unit removeing the top panel completely from the machine. If you look where the water lines connect to the rear of the machine on the inside would be the water inlet valve and you can test to each top plug in that you are getting power to each solenoid if you were getting power then you would unscrew your hoses and check for any debris caught in the screens that filter the water going into your machine.if you were not getting power to the water inlet valve then you would look at the pressure switch which is located on the oppisite wall of the unit. I await your reply to find out about how your test was with water inlet valve before posting further fixes for the pressure switch Thanks Rick
Posted on Jun 29, 2011
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
Tip
To maintain your front loader washing machine in good working order and to avoid...
To maintain your front loader washing machine in good working order and to avoid having a service call there are a few simple maintenance tasks to carry out.
1. Every time you carry out a wash before you switch on the unit you should check the door seal for any foreign particles like coins or hair clips and remove them. If they stay there they can then get past the seal and clog up the fluff filter and drain pump which stops the unit from draining.
2. It is also a good idea to wipe the door seal occasionally
3. There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap.
Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand.
Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight.
This should be done regularly every 2-3 months to avoid the unit from not draining.
4. Running a cottons 95c wash every 2-3 months kills off any bacteria build up, and cleans out any excess detergent build up. It also stops the unit from smelling.
You can also use a special washing machine cleaner or just white vinegar as a cleaning agent in the detergent tray to help.
5. After every wash keep the door open for about 30 mins to let it dry out as shutting the door is then a perfect environment for bacteria to develop and the door seal to go mouldy and also causing the unit to smell.
6. Lastly take care when removing clothes as zips can catch on the rubber door seal and tear it. This will then leak water at the bottom of the door.
Hope this helps.
on Mar 26, 2010 | Kitchen Appliances - Others
Tip
How to maintain your Front loader washing machine.
3. There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand.
Hope this helps.
on Mar 21, 2010 | Washing Machines
How do I clean the filter on the Novotronic W 310 Miele washing machine
Cleaning the fluff filter and pump
Check the fluff filter initially after 3 - 4 washes to ascertain how often it is likely to require cleaning. With normal cleaning approx. 2 litres of water run out.
If the drain outlet is clogged, more water will be retained in the machine (up to 25 litres).
Caution: if laundry has been washed at a high temperature,
water draining out of the machine will still be hot!
Take the (yellow) filter flap opener from behind the detergent drawer facia panel. Open the flap.
Place a dish under the drain fixture. Turn the fluff filter lid round 2 - 3
times. Do not take it right out.
With large volumes of water when the dish is full, screw the fluff filter back into position and empty the dish before repeating the procedure.
Once the flow of water ceases, remove the fluff filter completely and
clean it.
Remove any foreign bodies (e.g. buttons, coins, etc.) and fluff.
Turn the impeller by hand to check that it is free to rotate. Any foreign objects causing an obstruction should be removed.
Clean the inside of the fluff filter housing. Remove any deposits of lime scale and detergent or foreign bodies from the thread of the filter housing and filter unit (as these objects can cause a leakage
of water). Put the fluff filter back and screw it in firmly.
Cleaning and care
To clean the water inlet filters
The washing machine has two filters to protect the inlet valves. These filters should be checked every 6 months or so, or more often if there are frequent interruptions to the water supply.
To clean the filter in the union in the open end of the inlet hose:
First turn off the stopcock.
Unscrew the threaded union connecting the free end of the inlet hose to the stopcock.
Remove the rubber seal from the recess. Using pointed pliers, take hold of the plastic filter bar, remove the filter and clean.
Put the filter and seal back in the reverse order and reconnect the
hose. Turn on the stopcock and check the connection is watertight.
Inspect the inlet hose which is subjected to high pressure while the machine is in operation. The hose should be replaced if there are small cracks in the surface, or if it has been otherwise damaged.
If replacing the inlet hose only use a hose able to withstand pressure up to 70 bar. Miele's own hoses meet this requirement.
To clean the filter in the water inlet valve:
Using pliers, carefully loosen the ribbed plastic nut on the inlet valve,
and unscrew.
Use water pump pliers to withdraw the plastic filter by the bar.
Clean, put back and secure.
The two filters must be put back in place after cleaning.
Mar 08, 2015 | Miele W310 Front Load Washer
Miele w310..drum fills with water slowly after a wash.put my head in...cant hear water leaking into it..
Did you open the water tap complete? When it is open all the way already, please close the tap complete and remove the hose and check the filter closest to the tap. Eventually clean it and put the hose back. Don't forget to open the tap again and check you did tighten the hose. (No leakage)
Feb 04, 2015 | Miele W310 Front Load Washer
How do you clean the filter?
There is a fluff filter on the front of the unit in the bottom left or right hand corner behind the service flap. Have a small tray, like a baking tray underneath it and open the flap with some sort of flat lever,coin or screw driver. Turn the tap about 1/4 of a turn and collect about a litre of water from the unit. When it has stopped draining unscrew the tap all the way out and clean the fluff filter which is the tap in your hand. Also have a look in the hole and you will see the drain pump at the back. Make sure this is free of any foreign particles and can turn. Then re-screw the tap back making sure it is tight. This should be done regularly every 2-3 months to avoid the unit from not draining.
Aug 20, 2010 | Whirlpool Washing Machines
I cleaned out the fluff filter on my Miele W1918 and now the water is draining out the bottom. There is a small drain hose to the left of the filter that the water is flowing out of . Any ideas
hi,
Dec 22, 2009 | Miele Novotronic W1918A Front Load Washer
Washer front loader
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and themachine cannot pump out the water. Try unblocking the fluff filterfirst at the bottom of the machine. This should work, if the faultappears again though and the fluff filter is clean your waste pipe isblocked and you need to flush this through. Can you tell what I've justspent my weekend doing, I have had to get the most unbelievable amountof limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Problem
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
97 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
